Originally posted by wjchiefs Hi I am New to this whole thing lol. I have been trying to shoot baseball games using a Nikon D60 with 18 to 55mm not so good lol.
Derrick,
First, please don't use that huge font again. Gives everybody a headache.
Now, to your question. What's wrong with the photos you took with the 18-55? I'm going to guess that the main problem is that you can't get close to the action, and you feel that a telephoto lens would be better.
I agree with the comments already made about the lenses you already bought.
The solution to your problem has a couple of parts.
First, you need to know what focal length you DO need. Or if you are looking for a zoom lens, what focal range would be appropriate? I'm going to suggest that you consider the Tamron 70-300 f/4-5.6 Di LD lens. Focal range is probably good for your purpose. And I'm guessing you're on a tight budget, too, and this lens is very reasonably priced. There's a Sigma counterpart as well, which is also good. Or, you might even consider one of the superzooms (from Tamron, Sigma or Pentax) in the 18-250 range—but these are more expensive than the Tamron 70-200 that I mentioned first.
Now, second, there's the problem of actually making the lens work. To capture sports action you need to use a fast shutter. And there's another rule of thumb suggesting that you keep the shutter speed faster than the reciprocal of the focal length, in other words, if you are shooting at 300mm, you'd want to use a focal length no slower than 1/300th sec. So you need a fast focal length for a couple of reasons. But now what you need to make that fast focal length work is LOTS OF LIGHT. Because the Tamron 70-300's minimum aperture of f/5.6 at 300mm isn't especially "fast", that is, it doesn't let in a lot of light.
If you are shooting in the daylight, might not be a problem. Most of these non-prime zoom lenses are really daylight lenses.
If you are shooting a night game in a ball park that has great stadium lighting, well, that might work too.
But if the lighting won't work, then you will need to increase the ISO until you can get the shutter speed you need.
Another approach is not to worry about going all the way to 300mm and simply learning to make the best use of what you've got (your 18-55). Or perhaps getting a slightly longer zoom lens (like the Sigma 17-70 f/2.8-4.5) or even a prime lens. You can make anything work for you if you understand what the lens can and can't do, and take advantage of what it can while working around what it can't. And if you really want to take sports photos that look like the cover of Sports Illustrated, well, then you really will need to spend some money on a sharp, fast, telephoto lens.
Will
