Originally posted by Noe Ik heb geprobeerd met mijn K10 en Sigma DC 18 -200 lens foto's te maken in een zwembad, maar welke instelling ik ook heb toegepast, alleen maar zeer weinig licht te herkennen op de foto's zoals je ziet, Wie heeft er een advies voor mij ? Is dit sowieso niet mogelijk met mijn combinatie of .....
Instelling tijd tijd 1/25 en F 5,6
I guess you are right, it is hard with this combination.
I assume you've used the long end of the 18-200mm lens.
The photo suffers from motion blur and under exposure.
The shutterspeed of 1/25 is too slow to ensure sharp pictures, even on a tripod you will see some motion blur of the people moving.
First you need to work with a faster shutterspeed, second you need to compensate for the light coming in through the window.
The last thing is done by changing the Ev value ([+/-] button and front wheel) to Ev +1.
In order to be able to use faster shutter speeds under such poor light, you have the following options:
1. Increase the ISO value, at the cost of more image noise.
2. Use a (much) faster lens (it that case you need an other combination), at the cost of more Euro's and loss of depth of field.
3. Use a flash capable of filling in over the distance you are working with.
I hope this helps.
- Bert
