Originally posted by tnis0612 I assume that if my batteries die with the shutter open I wont get an image. Is that correct?
I'm curious as to how long a fresh set of Eneloops will last in the k-x during one long exposure. Does anybody have any experience with this? I'll be out camping and want to try some star trails and wont have the ability to plug in. Thanks!
I wish I had facts and figures but I don't.
I do know that long exposures do severely drain the batteries.
When, unsuccessfully, trying to capture lightning flashes I stacked neutral density filters and a polarizer to make exposures as long as six minutes but the batteries still retained some charge.
I should think you will need power to record the image as it is not an instantaneous procedure with long exposures and continues for a while after the shutter is closed.
Why don't you put your camera to the test. Leave the shutter open until the fully charged batteries die and time it. Bear in mind that shorter long exposures will allow the batteries to bounce back a little so you will get longer total use from them with repeated long exposures of shorter duration.
If you do make such a test please let us know the results.
Mickey
