05-19-2010, 06:10 PM   #1
Will screw mount lenses work on the digital pentax cameras?
What is a screw mount lens? will that work on dslr pentaxes? Thanks
05-19-2010, 06:39 PM   #2
Steinback's Avatar
Yes, M42 screw mount lenses will work on K mount Pentax bodies, though you will need an M42 to K adaptor to do so.
Check out this article: https://www.pentaxforums.com/forums/pentax-lens-articles/3800-can-i-use-m42-s...ns-reflex.html
05-19-2010, 06:41 PM   #3
SpecialK's Avatar
Look in the "Lenses" link at the top of the page.
05-20-2010, 04:11 AM   #4
Screw mount lenses preceded current lens mounts (like the K mount, EOS, etc). To use them on Pentax DSLRs, you need an adapter and then to do stop down metering. Quite easy to do and (depending on the lens) quite worth it as well.
05-20-2010, 03:35 PM   #5
GerryL's Avatar
There are also different kinds of screw mount lenses though so make sure you get the M-42 kind.
Each screw type mount would need a different type adapter.
05-23-2010, 11:25 AM   #6
Be careful as well ... as T-mount and M42 mount are both 42mm in diameter ... just the thread pitch is different.
Best place to look of good quality M42 glass is actually here in the Marketplace within this forum ... as you will find the gear is well looked after ... unlike on eBay where it can be hit and miss with equipment quality.
05-25-2010, 08:53 AM   #7
GerryL's Avatar
Make sure that it is M-42 and will fit Pentax.
In your searches include "screw mount"..M-42..Pentax".
camera, pentax help, photography, screw, screw mount lenses
Looking for Pentax screw mount lenses? 7.62lew Pentax SLR Lens Discussion 2 02-12-2010 03:44 AM
Three screw mount cameras compared Nesster Pentax Film SLR Discussion 11 10-30-2008 03:27 PM
where to buy screw mount pentax lenses sunita Pentax SLR Lens Discussion 5 06-19-2007 06:54 PM
Pentax Screw-mount Cameras & Lenses Matthew Roberts Pentax Film SLR Discussion 7 04-21-2007 02:53 AM
All times are GMT -7. The time now is 02:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
