Originally posted by spystyle I look forward to trying some manual lenses on a K-X and see how it does ... Now I just need a K-X
OK back on topic - it might not be that helpful for the OP -
but the K-x can help
A LOT -
one of the strongest features of the K-x and the main reason I bought one is its lead in class high ISO performance (see this
telling comparison at dpReview) - I can more or less shoot with impunity at ISO5000 (AutoISO set for max of ISO5000) - so much so that I do not own any fast prime lenses and exist quite happily on the two humble and looked-down-upon kit zooms 18-55 and 50-200 - because I value being able to frame my shot with zooms.
(the thread
Kx in Use is full of High ISO K-x shots - sorry non-dance though)
However there is very good reason for a faster lenses -
I do know one can get a manual Pentax 50mm f/1.7 for cheap -
that is if a 75mm equivalent lens is suitable.
I find myself tempted many times -
but when I look at my photos I find most are shot at wide angle between 28-35mm equivalent (ie: 18-24mm actual)
and the 18-55mm doesn't give much away in max aperture of f/3.5-f/4 at those focal lengths
and a real 18mm f/2.8 costs a lot which gains me maybe 2/3 stop -
but loses out on the flexibility to zoom.
Perhaps higher ISO is the way to go -
the OP's K20D may have higher noise - but careful RAW processing and use of a good noise reduction software like Topaz deNoise or NoiseWare (there is a free community edition) may help mitigate that - certainly ISO3200 or even ISO6400 may help capture the shots with existing lenses.
The only hint I can suggest is to look for the peak in the ballet sequence - sometimes in ballet they actually pause hold the pose at the apex - so shoot then -
but make sure to have pre-focused first (half-depression of shutter) ready to trip the shutter - so there isn't any delay due to camera focusing.
