05-26-2010, 10:17 AM   #1
Can't do Firmware Upgrade w/Transcend 8GB Micro SDHC w/Adapter
Hi, I put a Transcend 8GB Micro SDHC in my new Pentax k-x, using an adapter, and am unable to do a firmware update with it. The camera formats the SDHC, and Windows recognizes it when I plug the camera in via USB, but absolutely nothing happens when I press the Menu button and turn the camera on - just the usual screen showing the present 1.0 firmware. Is it likely because of the adapter?
TIA!
EDIT: It's a Class 6 card, if that's useful to know....
05-26-2010, 11:17 AM   #2
Are you putting the file into the root directory or into the DCIM directory? Firmware update only works when the firmware is at the root directory.
Thank you
Russell
05-26-2010, 11:19 AM   #3
QuoteOriginally posted by Russell-Evans Quote
Thank you
Russell
Hi, thanks for responding. I'm putting it in the root - although I did try putting it in DCIM after that failed. Neither worked. I've taken the card out, put it back in, reformatted the card three different times and tried it with the bin file in the root. Somehow I don't think trying it again will be the time I get lucky.
05-26-2010, 12:07 PM   #4
Okay, never mind, problem solved. Camera is updating as I write this. Turns out I was using the wrong firmware update. I thought I had downloaded the update for the k-x, but it turns out it was the one for the k-m. Doh! Sorry to waste your time.
05-26-2010, 12:43 PM   #5
hcc
hcc's Avatar
Glad that you resolved the problem. And welcome to the forum that is a good place to share problems and issues, as well as success and enjoyment.
05-26-2010, 12:54 PM   #6
QuoteOriginally posted by hcc Quote
Glad that you resolved the problem. And welcome to the forum that is a good place to share problmes and issues, as well as success and enjoyment.
Thanks. I've only taken a few test shots so far, but I'm impressed by the quality, even with the kit lens. Took a few shots of a tiny fly out in the back yard and was surprised how well the pictures came out using the default settings.
05-26-2010, 01:14 PM   #7
Senior Moderator
Parallax's Avatar
QuoteOriginally posted by imno007 Quote
...........Sorry to waste your time.
Welcome to the forum. Neither asking for nor giving help is ever a waste of anybody's time.
adapter, camera, firmware, pentax help, photography, sdhc
Verbatim and Transcend class 6 sdhc cards not fast enough for K-7 video pasipasi Pentax DSLR Discussion 17 08-08-2009 08:47 AM
If anyone needs 8gb SDHC cards..... speedoo Pentax Camera and Field Accessories 6 01-16-2009 11:10 PM
Transcend 8GB microSDHC Card - Class 6 Fl_Gulfer Pentax Camera and Field Accessories 23 01-12-2009 07:57 PM
Dell.ca 8GB SDHC class 6 for $54.99 vizjerei Pentax Camera and Field Accessories 0 02-26-2008 02:41 PM
8gb Transcend SDHC Class 6 under $40 mwcfire Pentax Camera and Field Accessories 10 02-25-2008 05:00 PM
All times are GMT -7. The time now is 01:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
