05-29-2010, 01:18 PM   #1
Pentax digital camera utility v 4.11 problem
Hi !!
I have just bought a K_X and installed Pentax digital camera utility 4.10
Suddenly the program does not work any more
When trying to start program I get message
PTXUTL40.exe have got problems and needs to be closed
I have downloaded version 4.11 but the same problem appear
If this problem not is solved I will use the warranty and cancel my buy of the Pentax camera and included program.
What to do to fix the program ??
I'm running Windows XP
Regards Tomas
05-29-2010, 02:09 PM   #2
Try first Uninstalling all versions of the Pentax camera utility software. Then install from the cd.
Perhaps the first installation had a problem. Just a suggestion. chig
05-29-2010, 02:38 PM   #3
Ira
1) Clean the CD with water and dry gently with a paper towel. A fingerprint smudge on the CD can mess you up.
2) Reinstall, and if that doesn't work, see if you can download the utility program from Pentax.
3) You have a computer problem here, not a camera problem. So returning the camera for this doesn't really make any sense. There are still many other
programs that can handle your processing/storage functions, and since the Pentax utility works fine for everyone, you have a computer/ program installation problem.
05-29-2010, 04:13 PM   #4
See this thread.
https://www.pentaxforums.com/forums/post-processing-printing-software-darkroo...4-problem.html
I had the same problem. Short story is remove the CheckInfo.ini file in the directory C:\Documents and Settings\<username>\Local Settings\Application Data\Pentax\Digital Camera Utility 4
05-30-2010, 07:20 AM   #5
hcc
hcc's Avatar
The earlier posts should resolve your problem. Simonb gave you an excellent advice. I had the same problem and deleting the CheckInfo.ini file solved it.
camera, camera utility, pentax, pentax digital camera, pentax help, photography, program, utility
Pentax Digital Camera Utility 4 tom_kkh Troubleshooting and Beginner Help 24 11-25-2012 02:28 PM
Pentax Digital Camera Utility 4 problem mba1971 Digital Processing, Software, and Printing 23 01-28-2012 07:31 PM
Pentax Digital Camera Utility 4, K7 and Lens corrections problem Labuzan Digital Processing, Software, and Printing 2 12-28-2009 10:09 AM
Pentax Digital Camera Utility 4 TeeDub Digital Processing, Software, and Printing 1 12-19-2009 04:55 PM
Digital Filters in Pentax Digital Camera Utility 4? lawsonstone Digital Processing, Software, and Printing 0 07-19-2009 04:44 PM
All times are GMT -7. The time now is 10:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
