Originally posted by maxwolfie I just read about the "Expanded Sensitivity" option in menu C1 - I.e. enables ISO 100 - 12,800 (!!!). I have enabled so I can shoot at ISO 100.
What else is in there that's worth fiddling with?
Highlight Correction is off, correct? And I think it has to be on the kx for expanded to work anyway.
I still use Shadow correction though, at the minimum setting.
You want to set your High ISO noise correction level, the ISO that noise correction kicks in, and the EXTENT of that correction. (Low, medium, or high,)
Next, hit your info button, and the first box (upper left) has your image settings. Select it, and you'll see there are a few choices for Natural, Bright, etc. However, you can adjust each one, so I just play around with my Natural setting to add a little extra saturation, sharpness, etc.
In other words, instead of selecting one of the presets, I just go back to the Natural setting and adjust the parameters.
