06-13-2010, 10:20 PM   #1
Aspect ratio - printing original size photos
I am a very novice photographer and I'm hoping this is something that is easily corrected. I'm using a Pentax K20D and iPhoto. When I request images to be printed the photos is automatically cropped and the sides get cut off. I have been told that this is because of the aspect ratio and the fact that traditional size prints don't match the aspect ratio. As a result the original composition is ruined. Any thoughts of how to correct this?
Thanks!
06-13-2010, 10:34 PM   #2
Marc Sabatella's Avatar
If the dimensions of a picture are 2:3, there is simply no way to print it 8x10" without cropping, any more than you can put a square peg into a round hole without shaving off part of the peg. You need to select a print size that's also 2:3, like 4x6" or 8x12".
Since this is a common beginner question, I'm moving it to the beginner's forum.
06-14-2010, 05:49 AM   #3
Lowell Goudge's Avatar
what size are you printing?
if it is snapshot sized they should print 100% of the frame, but larger printing media is different.
YOu have traditional print sizes like 8 x 10, and also you have sizes driven by standard printing papers, such as 8 1/2 x 11 etc.
but if you are dealing in small prints they are typically 4 x 6 or 3.5 x 5 which both print virtually the full frame.
06-14-2010, 06:12 AM   #4
SpecialK's Avatar
Print full-frame on the paper and use a matte frame to crop it - it's done all the time. Or, get used to looking at white borders (like black frames on the TV).
aspect, aspect ratio, camera, pentax help, photography, photos, ratio, size
Aspect ratio & image viewing... FHPhotographer Photographic Technique 2 02-06-2010 08:11 AM
Printing photos from DSLR..... shawn474 Digital Processing, Software, and Printing 13 04-05-2009 07:17 PM
Pano aspect ratio? schmik Photographic Technique 9 10-11-2008 02:20 AM
Prints and the sensor aspect ratio monstermagic91 Photographic Technique 4 09-19-2008 05:26 PM
Printing Photos at Home Gadget_Guy Photographic Technique 6 04-08-2008 05:24 PM
All times are GMT -7. The time now is 10:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
