06-17-2010, 08:15 AM   #16
Thanks everyone for all the advice and suggestions.
It does appear that it was simply the focusing screen I was seeing and my diopiter had shifted to where it looked awful.
However, in resetting it I began to wonder just where it should be set to? Is there a technique to this?
Thanks,
Ken
06-17-2010, 12:29 PM   #17
Marc Sabatella's Avatar
It's covered toward the very beginning of the manual. Basically, you are trying to get the viewfinder *info* display (the etched lines, the digital readouts at the bottom) as sharp as you can. The "0" value is something like two or three clicks from the right on most cameras, I believe.
07-19-2010, 11:48 AM   #18
nanhi's Avatar
View Finder Fuzzy
Some one in this Forum mentioned a loose Focusing Screen door as a probable cause of fuzziness in the view finder.
Do take out the lens and check. All you do is push the door up to lock it securely.
The diopter adjuster is a big culprit too.
camera, pentax help, photography, viewfinder
Dirty Sensor Or Dirty Lens? Orli Troubleshooting and Beginner Help 8 10-26-2009 03:35 AM
A Dirty Dozen metroeloise Post Your Photos! 4 07-12-2009 12:21 AM
Dirty Taff Post Your Photos! 8 04-27-2009 06:41 AM
something dirty, somewhere? FHPhotographer Pentax DSLR Discussion 7 03-10-2009 08:28 AM
All times are GMT -7. The time now is 09:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
