Originally posted by simico In that case (same pixel density) there's no high ISO advantage. High ISO advantage can come from lower pixel density/larger photosites and advances in electronics (and to some degree, advances in firmware noise reduction).
Well, actually, in that case (same pixel density), there IS an advantage to FF, as it will have a lot more pixels (thus a less visible noise) for
the same output size.
Say you have a 14.5MP aps-c, with a 200/2.8 lens, vs. a 21MP FF with a 300/4 lens : equivalent DOF and FOV, you have to use an one and a half higher iso on the FF, but you also have some 6.5MP extra resolution.
The pixel-level noise (
seen when pixel-peeping both pics at 100%) is indeed more present in the FF pic.
(but in real life, FF photosites being usually bigger than those on APS-C, noise handling is better, and the noise difference between the two system comes well below the 1-1/2 stops difference of my example)
But, for the same final output size, the extra noise will be offset by the greater resolution, where the extra 6MP will "hide" the additional noise. And that's not even with the same pixel density, where the difference would have been even more to the advantage of the FF system.
So, for a given DOF/FOV, equivalent lenses are not actually much that cheaper/smaller in APS-C, and sometimes do not exist altogether (there is no equivalent to the good old 50/1.4).
What would cost a 50-135/1.7? I bought my Tamron 70-200/2.8 for 650€, and it does wonders on my film camera, but there is no equivalent lens for my K7, and there will never be one...
Only real price/weight difference is in the body...
