06-19-2010, 10:38 AM   #1
I've bought a Pentax K1000 & Weston V
Dear Group, for years i have used a Chinon CE4, which i bought maybe 25 years ago. I took it with me on a trip to Madrid last month and it let me down, the shutter failed to respond, but i guess it doesn't owe me anything.
Anyways, afetr scouring Ebay i found a mint condition K1000. And when i say mint i mean mint, not a single sign of use whatsoever.
I also found, and bought, a beautiful Weston V light meter, for no other reason that it looks wonderful and it was just 4.
So, i was wondering if i could still use such an old meter, it appears to be in full working order.
I tried it just the other day in my garden, i focused my Pentax quiet close up to a sunny brick wall and noticed the settings according to the TTl meter then i checked with the Weston and they were the same. I then focused the Pentax at a variety of things, my neighbours rooftop and the bottom of my garden and again noted the settings. The Weston gave me slightly different readings, but nothing to a set pattern, some were slightyl higher, some a tad lower.
My question is, is this the sort of behaviour i can expect, will the Weston read different light levels in different situations compared to the K1000's light meter?
Thanks for your help chaps.
06-21-2010, 01:58 AM   #2
The Weston should read more or less the same light quantity as the camera, as long as it is measuring the same surface/composition.
The light meter's opening and measuring angle, combined with distance and direction is what makes it capture light.
I guess it is hard to have your camera's lens is capturing the same composition allways.
For instance, if your subject is 100 ft away, you may see a very different reading with the camera using an 18mm or a 200mm lens. The latter might only "see" a shadow or high light zone of the composition of the 18mm lens.
While your light meter will always read out the same from that distance.
- Bert
camera, garden, k1000, light, meter, mint, pentax, pentax help, pentax k1000, photography, settings, weston
Bought a K1000 SE on ebay, what should I look at when I get it? ero Photographic Technique 1 12-27-2009 01:08 PM
For Sale - Sold: (US) Pentax K1000 ($10) & Asahi 49mm UV ($10) ddjchemist Sold Items 3 10-11-2009 12:49 PM
For Sale - Sold: Pentax K1000 & 50mm f2 lens KmountShooter Sold Items 0 06-08-2009 07:51 AM
All times are GMT -7. The time now is 10:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
