06-29-2010, 07:08 AM   #16
Pablom's Avatar
I really don't think you need any more than the manual to operate your camera. any further reading I recommend should be general photography books and not necessarily specific to your camera, as I believe that will serve you best.
when I started I read a couple of books for beginners, one was the National geographic photography field guide and the other was the 35mm handbook by Michael Langford (this one is really old). none of them dealt with digital photography but there's nothing special in it really, once you get the basics you'll catch up the rest as you shoot.
06-29-2010, 06:51 PM   #17
Marc Sabatella's Avatar
+1 on the National Geographic Field Guide. I learned way more from it than from my camera manual. Not sure I ever really would have figured out what Av mode really was or what exposure compensation was without seeing it explained in plain English first. Between the National Geographic guide (a very old edition) and a book on DSLR's, I was pretty well set.
06-29-2010, 08:05 PM   #18
QuoteOriginally posted by cdndave Quote
Hi
this is my first post here, I've been lurking here awhile
I bought Yvon Bourque's K-X ebook from his blog (Pentax e-books), I read it and thought it was a gentler version of the manual.
Dave
Welcome to the forum. Nice to see somebody with a fresh idea.
06-29-2010, 09:43 PM   #19
SpecialK's Avatar
QuoteOriginally posted by 4ngi3 Quote
point taken.. i really need to RTFM.. but its just soo big!!
So just read the part you have the question about.. It's not the bible :-)
04-28-2014, 05:58 PM   #20
hi im also using pentax kx and actualy this is the very first time to use a dslr camera.... how can i tried to set low the aperature but it can only do F5.6...... and i've read about the lense issues, im using 18-55mm lense so how can i know the lowest aperature can be done by this? i didnt see it in the manual
---------- Post added 04-28-14 at 06:00 PM ----------
hi im also using pentax kx and actualy this is the very first time to use a dslr camera.... i tried to set low the aperature but it can only do F5.6...... and i've read about the lense issues, im using 18-55mm lense so how can i know the lowest aperature can bmanuale done by this? i didnt see it in the manual
04-28-2014, 06:12 PM   #21
QuoteOriginally posted by khaiza Quote
At 55mm, the fastest aperture is F5.6. At 18mm you'll be able to select F3.5. Between 18 and 55 you'll be in the F4-4.5 range.
04-28-2014, 07:08 PM   #22
ah so it means, if i have to set my lens into 18mm, i need to get close to my subject? i tried to shots (18mm and 55mm) am i do it right? thank you so much and sorry im really not good in taking picture this only my 3rd day having my camera
PENTAX K-x  Photo
PENTAX K-x  Photo
04-28-2014, 07:11 PM   #23
yes- 18mm is less zoomed in, while 55mm is more zoomed in. The bigger the number, the more the lens magnifies, essentially.
04-28-2014, 07:13 PM   #24
ahhhhhhhhhhh now i learned that thing thank you so much sir more power
04-30-2014, 11:10 PM   #25
rfg
I second the recommendation above for Yvon Bourque's k-x ebook. As well as the camera it covers a lot of photography basics.
Here's the link: Pentax K-x & K-r e-book
18-55mm, aperature, aperture, camera, change aperture, didnt, dslr, im, issues, kx, lense, light, pentax, pentax help, pentax kx, photography
Hope and Change , "Hey mister can you spare some change?" seacapt General Talk 19 04-13-2010 05:56 AM
Constant Aperture vs Variable Aperture Netsoft Pentax SLR Lens Discussion 13 01-11-2010 07:29 AM
Use of Aperture-Ring 43mm/1.9 -> no aperture data Deimo Pentax SLR Lens Discussion 7 06-24-2009 03:25 PM
A Change cupic Post Your Photos! 4 04-28-2009 05:17 AM
To change lenses or not to change lenses. That is the question. atyab Photographic Technique 28 11-24-2008 09:27 AM
All times are GMT -7. The time now is 07:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
