07-13-2010, 12:48 PM   #16
QuoteOriginally posted by Parallax Quote
It doesn't matter. If you meter off of your palm you are determining the correct exposure based on the EV of the scene. What is in the scene is irrelevant. It is no different than if you use a grey card or an incident light meter. Correct exposure is correct exposure.
When a scene has more light than your camera can capture, you have a choice to make. Expose for the high values and go with accent blacks. Expose for the low values and have accent whites. Or go for some middle and have both accent white and black. Which is the "correct" exposure?
07-13-2010, 12:53 PM   #17
Senior Moderator
Parallax's Avatar
Whatever you want it to be.
07-13-2010, 01:04 PM   #18
That's what I'd say too.
07-13-2010, 01:09 PM   #19
Lowell Goudge's Avatar
it seems to me that this thread has mutated from a substitute for a greycard, to definition of perfect exposure.
I think the first is easy, from experience find something that you can meter off of, and know how many stops you need to add/subtract to put the metered "something" where you want it in a histopgram.
the second one is impossible since this is to some extent an art and no two artists agree.
07-13-2010, 04:44 PM   #20
Thanks for all the input guys.
My wife is taking a photography class and the first thing they are teaching is to correctly expose an image. I am thinking the palm of my hand is pretty good to meter at zero. My wife needs to dial in +1 compensation when metering off her hand.
I prefer to find a black or white and meter off of that because it is pretty easy to find either black or white in just about any photograph.
Thanks again guys.
camera, card, meter, palm, pentax help, photography, question
sd card question wvc Pentax Compact Cameras 6 04-20-2010 08:02 PM
Can I customize whitebalance in camera with a grey card dkittle Photographic Technique 21 02-08-2009 05:53 PM
SD card question Fl_Gulfer Pentax Camera and Field Accessories 5 07-07-2008 07:19 AM
man whi bal only with grey card? arthur pappas Pentax DSLR Discussion 9 02-27-2008 03:36 AM
Grey/Gray Card LittleSwans Photographic Technique 15 06-11-2007 08:33 PM
All times are GMT -7. The time now is 08:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
