07-10-2010, 03:05 PM   #1
netuser's Avatar
k-7 and fill flash gives me shake/blur/motion images?
Hi guys
I need your help
Today I was using fill flash on AF540FGZ with k-7
I noticed my images were not sharp so after a while I turn the flash off to not waste power while trying to check what was going on. Change between lenses and same problem .
Then I allow the in camera mode for shoot even when flash recharches and tried.
Guess what, image taken with flash is blured or something, the ones without fill flash are OK.
What I'm doing wrong?
Check the full images with exif here (direct download from my zenfolio account) if you care to download and help me.
http://myviews.zenfolio.com/p128511190/h30ef78cf#h2c318303
Thanks in advance
07-10-2010, 04:15 PM   #2
SpecialK's Avatar
It looks OK to me.
07-10-2010, 04:18 PM   #3
Lowell Goudge's Avatar
I could not get the exif data but one thing to consider is that with fill flash the burst can be very short, and it is better to do trailing curtain sync so the flash goes at the last place the person is located in the frame, giving a sharp edge at the end of movement.
if you have an extremely slow shutter speed, in an automatic mode, motion blurr with daylight exposure cans till kill you.
I always shoot flash in manual mode to force the shutter speed to the place I want it.
07-10-2010, 04:35 PM   #4
netuser's Avatar
I'm used to have razor sharp images and these are not.
Maybe it's what you say, I need to go manual with the flash!
Images can be download as original from my zenfolio.
Exif is on them:
File type: JPEG
Make: PENTAX (PENTAX)
Camera: PENTAX K-7
Lens: smc PENTAX-DA 12-24mm F4 ED AL [IF]
Software: K-7 Ver 1.03
Dimension: 4672 x 3104*px*(14.5 MP, 3:2)
Focal length: 19*mm*(equiv. 28*mm)
Aperture: F8
Exposure time: 1/100" (+0.3*EV)
ISO speed rating: 100/21
Program: Aperture Priority
Metering Mode: Center-weighted average
White Balance: Auto
Focus Mode: AF-S
Image Stabilizer: stabilized
Noise Reduction: Off
Flash: Flash fired, compulsory flash mode
File type: JPEG
File size: 6.215,2*KB
Camera: PENTAX K-7
Aperture: F8
White Balance: Auto
Focus Mode: AF-S
Flash: On, flash did not fire
07-10-2010, 05:43 PM   #5
Marc Sabatella's Avatar
The flash shot doesn't obviously look less sharp than the non-flash shot. Neither have a very clear focus point; I'm guessing that's really the only issue here. Had you focused on one of the faces in particular, it would have been sharper, but the focus isn't anywhere in particular that I can tell.
07-11-2010, 03:22 AM   #6
netuser's Avatar
Yeh, I didn't pick two good samples for the purpose!
camera, check, download, flash, images, k-7, pentax help, photography
Fill flash for K10D with AF360 flash unit dichro1 Troubleshooting and Beginner Help 1 12-03-2009 03:08 PM
Motion Blur Portrait jmbradd Post Your Photos! 2 03-11-2009 01:30 PM
Slow flash - fill in flash - k100d soalle Pentax DSLR Discussion 4 06-21-2008 02:06 PM
Weekly Challenge #23 - Motion Blur Jonas B Weekly Photo Challenges 43 07-13-2007 08:27 AM
Motion blur Donald Post Your Photos! 3 04-30-2007 07:23 PM
All times are GMT -7. The time now is 12:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
