07-12-2010, 02:41 PM   #1
jaieger's Avatar
Question on Magnification Ratios
Hi all, just wanted to get a confusion cleared up about the magnification ratios..What do they mean, exactly? If a lens has a max magnification ratio of 1:1, or 1:2:7, or 1:3x10^8, what does that mean? Also, why are macro lenses only considered macro (in the purest sense) at a 1:1 ratio? In my mind, a 1:1 ratio means the subject (let's say, an ant) would appear in the picture at a 1:1 ratio of how it appears in real life, ie., 3-4 cm or something on an 8x12 print or 5x7 print or whatever.
07-12-2010, 02:52 PM   #2
QuoteOriginally posted by jaieger Quote
Almost correct.
Using your words: a 1:1 ratio means the subject (let's say, an ant) would appear on the camera's sensor at a 1:1 ratio of how it appears in real life.
The width of the APS-C sensor in a Pentax DSLR is about 24 mm. Here is a photo of 1:1 (note the ruler in the background):
So 1:2 ratio means the subject appears half as large on the camera's sensor as it it in real life.
07-12-2010, 03:04 PM   #3
Lowell Goudge's Avatar
correct SOldBear, Ideally people would always relate to the image projected only by the lens, but unfortunately people get this idea to , for example talk about the focal length factor of the cropped sensor. That really screws things up, as opposed to discussing field of view, which is correct.
one thing to point out however is that when discussing shutter speed to stop image blurr, and depth of field, both of these issues are a function of print size, because you are more likely to notice the lack of sharpness the bigger something is printed.
07-12-2010, 03:21 PM   #4
jaieger's Avatar
Hmm, okay. And what about the ratios that have 3 numbers, what does that mean?
07-12-2010, 03:34 PM   #5
An example of three ratios would be helpful
07-12-2010, 03:40 PM   #6
jaieger's Avatar
I don't know exactly where I've seen them, but I know it's not uncommon, cause I have seen it multiple times...magnification ratios stated as 1:2:7 or 1:2:4, etc.
07-12-2010, 03:46 PM   #7
I think they are 1:2.7 or 1:2.4.
Same thing applies: The size in real life is 2.7 (or 2.4) times as large as the size on sensor.
07-12-2010, 09:30 PM   #8
DAZ
DAZ's Avatar
One more thing to point out. This ratio is usually when the object is closest point to the lens that it can focus on i.e. minimum focal distends. So if you have 2 lenses that are 100mm both will give the same FOV but if 1 can focus to 3 feet and give a 1:1 and the other only 6 feet then it maybe 1:2.
DAZ
07-13-2010, 09:45 AM   #9
Marc Sabatella's Avatar
Magnification ratios are never given as 1:2:4. It's possible you've seen something like 1:2,4 if the number was provided by someone in a country that uses commas instead of periods for decimal points (eg, much of Europe, I believe).
As for why 1:1 is considered "true" macro, it's just a convenient round number to use. it's not like there is some magic line that makes 1:1 that much better than 1:1.2. Kind of like in baseball a hitter is considered good if he hits .300, but it's not liek that's relly that much better than if he hits .291.
camera, macro, magnification, pentax help, photography, print, ratio
Aperture and Light Ratios D4rknezz Photographic Technique 5 06-18-2010 12:37 PM
Please help with Lighting and Ratios.... D4rknezz Photographic Technique 7 06-14-2010 03:09 PM
Magcro Magnification Ratio Question GregK8 Pentax SLR Lens Discussion 18 03-16-2010 10:17 PM
AF-540 flash ratios jedcrocker Flashes, Lighting, and Studio 0 01-25-2010 07:29 PM
Macro Magnification ccallana Pentax SLR Lens Discussion 3 04-20-2007 03:03 PM
All times are GMT -7. The time now is 10:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
