07-12-2010, 04:08 PM   #1
Using a MF 75-200 Zoom Lens in Kx
I picked up a old Soligor 75-200 + Macro lens that I'm using on a Kx. When I mount the lens and turn on the camera I need to enter the focal length.
Does it matter what I input? The shots seem to be coming out OK regardless.
07-12-2010, 06:04 PM   #2
KxBlaze's Avatar
As a general rule of thumb you can input a focal lenth that is close to the mean. So for your 75-200 I would input 135-140 but I really think it doesn't matter.
07-12-2010, 06:19 PM   #3
SpecialK's Avatar
It does matter, because there is more shake/movement at longer lengths, but I don't know how much :-) The manual- focus zoom is the least compatible of the "24 million" lenses that will work on Pentax cameras for that reason.
07-13-2010, 09:51 AM   #4
Marc Sabatella's Avatar
In case it isn't clear, the only reason you need to enter focal length is so the SR system knows how much to compensate for camera shake - the same actual amount of shake has a greater effect and therefore needs more compensation at longer focal lengths. If you enter too high a number - by at least a factor of 2X - the system could overcompensate yby som much that you'the results are worse than simly turning SR off. So it's best to understate the focal length. well, it's *best* to re-enter focal length every time you zoom, but obviosuly, that's not very practical. just do what makes sense to you now that you understand why you are entering a number. If you plan to mostly use it a 75, entering 150 would be bad - probably worse than non SR. if you plan on mostly using at 150, though, entering 150 would be fine. if you have no idea where you'll be using it, then it's better to err on the side of picking to low a number than too high. I'd probably go with 100.
07-13-2010, 03:28 PM   #5
Thanks for all the great advise. Now that I understand, I guess it also safe to say that if I use this lens while the Kx is mounted on a tripod, the FL setting won't matter at all being that I have to disable SR anyway.
camera, kx, lens, pentax help, photography
Granit 80-200 Zoom Lens(Russian m42) regken Pentax SLR Lens Discussion 9 10-05-2013 10:32 AM
For Sale - Sold: Pentax DA50-200 zoom lens StevenVH Sold Items 3 02-28-2009 09:31 PM
Decent zoom lens for under 200 bucks? vmax84 Pentax SLR Lens Discussion 8 02-15-2008 06:16 AM
Sakar MC auto zoom 80-200 lens Shefali Pentax DSLR Discussion 2 02-26-2007 03:35 AM
All times are GMT -7. The time now is 10:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
