07-13-2010, 04:14 AM   #1
Banned
Some problems with pics on holidays
Hello,
we are currently on our 3rd day of our holidays, however we need some tips as we have some problems with our k_x...
BAsically thw weather here is not that good and it is very cloudy. so if we need to take a photo of something, the colour of the clouds makes it very difficult to use the perfect settings. any tips for taking photos on such situation?
Also we are trying to use flash, but whilst on manual mode, when i use flash i cannot control well the setting, and thus i go straight to auto mode. What should i do to use flash on manual mode?
Thanks, and i hope i am a bit clear!
07-13-2010, 05:19 AM   #2
Ira
You're asking too many complicated questions, but first, the camera's flash is not going to help you outside anyway, unless you're doing a portrait. It's not strong enough
The best thing you can do for yourself now is make sure you have Automatic ISO selected, and shoot in P mode.
07-13-2010, 08:20 AM   #3
Banned
Ok thanks for the answer,
the problem is that everything is dark because of the background which is white when we use any of the auto settings and we need to use manual all the time...
This Is why any of the settings , auto ones, we use are not good.
07-13-2010, 09:28 AM   #4
Marc Sabatella's Avatar
Well, if the background *is* a lot lighter than your subjec,t the camera is capturing that fact accurately. It's up to you to decide whether you've rather have a well-exposed subjkect or well-exposed background, but you can't have both in the same shot unless you change the lighting. So it's not clear what you are asking. I usually expose to only "slightly" blow out the background, which will still result in an underexposed subject and I then brighten the subject in post processing (the "fill light" tool in many programs can often do a good job of this).
07-13-2010, 12:36 PM   #5
SpecialK's Avatar
QuoteOriginally posted by fekish Quote
When the sky is white you will have to add some +EV compensation. P mode works somewhat like Auto but you can still change many settings.
07-13-2010, 05:56 PM   #6
Banned
Ok thanks for the help again.
We manage to get good photos as I use manual mode. However when I need to give the camera to some friends to take us photo, then I need to select something else than manual mode for them...
Thanks for the tips again!
camera, flash, holidays, mode, pentax help, photography, tips
Holidays!!!! Mallee Boy Post Your Photos! 9 03-06-2009 08:36 PM
Anyone Having Problems Uploading Pics On Hewre (Photobucket) shutterpuppy Photographic Technique 1 02-07-2009 03:30 PM
Need help with exposure problems and snow photography problems, urgent please respond montezuma Photographic Technique 7 02-24-2008 05:43 PM
Remnants of the Holidays Sailor Post Your Photos! 3 02-25-2007 06:19 AM
Happy Holidays to all nate Post Your Photos! 7 12-25-2006 06:03 AM
All times are GMT -7. The time now is 11:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
