07-14-2010, 03:06 PM   #1
Kx AF Points
I'm thinking of buying a Kx as my first DSLR, and from the reviews it seems great. I'm just a bit concerned that everything i've read about it criticizes it for its lack of AF points.
I sort of know what these are, but i'd appreciate it if someone could tell me what this means in practical terms - does it prevent me from taking some shots? Is it really that much of a drawback for an amateur?
Sorry if this is a dumb question.
thanks
07-14-2010, 03:56 PM   #2
No, this isn't really a drawback for most people. AF points are simply points on the frame where the camera can measure the focus. In 'green' AF mode, the camera automatically picks which of these 11 points to focus at. However, many people, including myself, simply set AF to center-only. That way, what you point at is what the camera focuses on. While holding down the shutter button halfway, you can then adjust your composition.
07-14-2010, 09:52 PM   #3
KxBlaze's Avatar
The lack of AF points will definitely not prevent you from taking any types of pics. As Adam said, all it does is let the photographer know which point the camera is choosing to focus on.
The problem with autofocus is that sometimes you and the AF do not agree. The AF will try to anticipate what you want to focus on but it will not always be what you intended to be the focus point. So I highly recommend using the Center Point Focus (mine has never left that setting), put your focal point right in the center of the viewfinder and readjust to capture your image.
07-15-2010, 03:29 AM   #4
Ira
If you're still confused, it means you don't SEE the actual visible indicators in the viewfinder. You can still set the point(s) to wherever via the LCD.
As said above, the majority of people use the center point anyway most of the time.
07-15-2010, 07:06 AM   #5
ChooseAName's Avatar
On a K200D (the one I have), once the camera focuses, there will be a beep-beep sound and a red dot will flash where the camera is focusing. If I am not mistaken (I have never handled a K-x), on the K-x, there will be no red dot.
07-15-2010, 08:18 AM   #6
Ira
QuoteOriginally posted by ChooseAName Quote
No dot indicating where it's focusing--correct.
07-15-2010, 10:21 AM   #7
Marc Sabatella's Avatar
If you don't know what they are, you don't need them. Their absence is only an issue for the small percetnage of people who have come to rely on them in other cameras, and just cannot imagine using a camera without them.
07-15-2010, 10:35 AM   #8
It makes sense to have them, though. I often don't know what my camera is focusing on and it would be nice for it to let me know.
07-15-2010, 11:37 AM   #9
Ira
QuoteOriginally posted by dragonfly Quote
If you're paying attention to what you see in the viewfinder, it's pretty clear to see what your camera is focusing on...more or LESS.
You should not depend solely on a beep, viewfinder focus point or lighted hexagon confimation to confirm focus.
That's what your eyes are for.
07-15-2010, 11:20 PM   #10
Aside from the fact that you can see in the viewfinder what's in focus, even if a dot lit up to tell you, its not like there is anything you can do about it should it light up somewhere other than you want. Well, you can, but not in the mode where the camera chooses the focus point. If you let the camera chosoe, there's no real added value in having it tell you what it did, since you can't do anything about it. It's really only when *you* choose the focus point that the indicators are particularly useful. You can d it using the LCD, but the viewfinder indicators make it easier. Still, if you're not already among the minority who like to select focus points themselves, then you'll never miss this.
07-17-2010, 04:29 AM   #11
Buy the k-x, it's worth it, the loss AF dots is bearable, and you will learn to rely in your eyes too, not just depend on the camera.
The Indian (wielder) is always better than his bow and arrows.
Peace.
07-18-2010, 07:25 AM   #12
Thanks for the help everyone! It seems like it's really not that much of an issue unless you're used to having it.
af, camera, kx, pentax help, photography
More talking points Nesster General Talk 3 06-30-2010 10:26 AM
Focus Points and Accuracy montman Pentax DSLR Discussion 3 06-09-2010 09:48 PM
K-7 Focus Points jolinjo Pentax DSLR Discussion 3 11-11-2009 01:41 PM
Finland 0 Points flaa Welcomes and Introductions 2 05-18-2009 02:57 PM
Nodal Points HGMonaro Pentax SLR Lens Discussion 3 06-06-2007 04:07 AM
All times are GMT -7. The time now is 07:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
