07-27-2010, 11:43 PM   #16
Banned
QuoteOriginally posted by MPrince Quote
Just out of curiosity, what are the names and issue dates of these photo magazines you refer to?
i'll check and let you know the name of the magazine. definitely were the latest month's issues, but only one of them i brought with me back home.
I'll let you know the name when i go home..
The foreign magazines were 15-20$ and the Malaysian ones cost around 3-5$
07-28-2010, 01:14 AM   #17
There's nothing broken, hence nothing to fix. The camera exposes very well according to ISO standards. It makes no attempt to read minds, but it does provide exposure compensation control - like every other camera - so you can tell the camera ow you want the exposure to differ from standard.
Yes I do understand that you can tweak exposures. I have the the Canon A550 mentioned by Fekish, and it does indeed manage exposures in "normal' picture situations much better than the Kx!
07-28-2010, 04:38 AM   #18
GeneV's Avatar
I looked at image #10. ISO 200, Aperture priority, f4, 1/400 around 8:40 pm. I don't know what your latitude is, but I'd say it was near sunset. Call it an EV of 9 or 10. At that ev, shooting at f4 with an iso of 200, your shutter speed should be 1/60 (ev 9) or 1/125 (ev 10), so yes, the shot is underexposed.
True, except that many of these shots are taken on an overcast day, but into the sun. The camera is preserving the detail in the sky. I think that may actually be the best exposure for these shots.
Two nights ago, I was scanning a few old rolls of slides of Switzerland from 30 years ago, taken with an MX. I often let that kind of sky in my slides go white to make a bright slide on the building or mountain, but if I tried, using my best manual skills (such as they were) to preserve the sky, I got the same kind of "dark" shot.
FWIW, the above color balance and exposure is where Photoshop places it using "auto" settings, as well. I suspect that 30 years may have shifted the Agfachrome color a bit.
If I override the auto settings in Photoshop and brighten and warm up the foreground (without masking), I lose the sky:
07-28-2010, 10:00 AM   #19
Marc Sabatella's Avatar
QuoteOriginally posted by marty-0750 Quote
Yes, some beginner level P&S cameras do attempt to attempt to "read minds" because they assume the photographer doesn't understand exposure well enough to make the necessary adjustments, and thus they perform some "auto adjustments" to attempt to produce pleasing pictures even though the results are not technically correct according to traditional photographic exposure standards (eg, those established by the International Organization for Standardization). You will find that DSLR's do not tend to do this - they tend to expose according to ISO standards, which do require use of compensation in well-defined situations.
07-28-2010, 10:32 PM   #20
Yes, some beginner level P&S cameras do attempt to attempt to 'read minds" because they assume the photographer doesn't understand exposure well enough to make the necessary adjustments, and thus they perform some "auto adjustments" to attempt to produce pleasing pictures even though the results are not technically correct according to traditional photographic exposure standards (eg, those established by the International Organization for Standardization). You will find that DSLR's do not tend to do this - they tend to expose according to ISO standards, which do require use of compensation in well-defined situations.
Ok then that seems to make sense. So it's like doing it the old way with film SLR's, like using the 16/125 rule, checking the viewfinder readings and tweaking manually. I checked my slide collection and found many under-exposures in outdoor landscapes similar to the K-x when using centre-weight metering before I knew how to compensate. By contrast evaluative metering does a better job of balancing the exposure for normal scenes. I prefer to use centre-weight as I know what it covers in the frame, but eveluative could be doing anything as it scans the distribution of luminoiusity over the frame to make its decisions - sometimes over exposing.
BTW Has anyone downloaded Pentax's firmware update into their K-x? Is it worth it?
Martin
07-29-2010, 03:50 AM   #21
Martin
It's free. Why wouldn't it be worth it?
07-29-2010, 11:58 AM   #22
Well, it's not *that* bad. All you really need to know if that when a scene is brighter than average, dial in positive compensation if you want it to *look* brighter than average, and when it's darker than average, dial in negative compensation if you want it to *look* darker than average.
I feel similarly - the matrix/pattern/evaluative metering could *potentially* figure a lot of stuff out, but it's much less harder to anticipate what it might do in a given situation. So it's hard to predict when compensation might be needed, and therefore I stick to good old center-weighted metering.
07-29-2010, 06:22 PM   #23
What I meant is it worth installing into the camera? I understand it's a bit risky if you stuff up the process it could result in a trip to the factory for a reset. And also by "worth it" I would be looking for enhancements such as illuminated red-focus-indicator (like in the K100D), and say, instant-access to user pre-set setups in the menu rather than have to run through repetitive button presses every time. Not interested in those "special effects" they seem to be offering in the current update.
Martin
07-29-2010, 08:41 PM   #24
I feel similarly - the matrix/pattern/evaluative metering could *potentially* figure a lot of stuff out, but it's much less harder to anticipate what it might do in a given situation. So it's hard to predict when compensation might be needed, and therefore I stick to good old centre-weighted metering.
Ok, I think I've nailed what's going on. It does appear light gets through the view finder and affects the meter reading. Especially in day light out in the open there is plenty opportunity for light to sneak in. This explains two things when using centre-weight metering:
1) exposures out in the open with a lot of light coming from all directions are consistently under exposed by 0.5 to 1.0 stop
2) when shooting under same outdoor conditions in live view exposures are more "correct" - why? because in live view the mirror flips up and entirely blocks light leaks from the viewfinder and prevents interference with the reading.
I road tested this with camera on tripod outdoors in the open and watched how the metering changed as I covered the view finder with my hand and then with live view on and off. Yep light gets in through the view finder alright and interferes with the reading. Also explains why many of my out-door-in-the-open slides from my Olympus OM1 are similarly under exposed.
So you need your wits about you when judging exposure with DSLR (& SLR).
Martin
07-30-2010, 08:50 AM   #25
Definitely when shooting on a tripod - that's why the camera comes with a viewfinder cap. Shouldn't be an issue in handheld shooting, though. I still don't understand enough abut how metering works with liveview, never having used a camera with that feature.
07-30-2010, 10:58 AM   #26
Ira
Martin
It fixes some bugs and is definitely worth doing.
camera, pentax help, photography, shots
EF-530 DG and K100D underexposed hoser Pentax DSLR Discussion 1 12-23-2009 01:12 AM
Underexposed without eye to viewfinder? WackySnapper Pentax DSLR Discussion 12 01-19-2009 01:07 AM
Underexposed pics k10d jjfdvm72 Pentax DSLR Discussion 85 02-26-2008 05:57 PM
Photoshopped Version 2.0 Not underexposed Quaffle Post Your Photos! 4 01-19-2007 10:11 AM
Dramatic or underexposed? Fox Three Post Your Photos! 10 12-06-2006 11:45 PM
All times are GMT -7. The time now is 12:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
