07-22-2010, 03:57 AM   #1
Kx or K7 for travel
I am looking for actual user feed-back in order to help me choose the most appropriate camera for travel.
First, the setting: traveling by car in Europe, mostly cities, dry climate, intend to shoot indoor and outdoor, streets and architecture, using the FA Limited trio.
Why the question:
At the beginning I thought about taking the Kx but the WB problems (meaning significantly less accurate than the K7) and the less performant SR made me think twice. In favor of the Kx would be the size and weight, the non threatening color (white), the use of AA batteries, the high ISO performance.
How one would cope with the WB - this is what I loathe the most about the Kx, and after that the LCD screen. Should I take a grey card, is it easy to manually set-up the WB?(never used a grey card before)
Thanks in advance!
07-22-2010, 04:37 AM   #2
ChooseAName's Avatar
QuoteOriginally posted by kytra Quote
Are people in Europe afraid of black cameras?
If you can't be bothered with using a flash, I might go with the K-x for the high ISO. I would think most WB problems can be fixed in PP, unless you are one of those who looks down on PP.
Of course, if you don't want to be switching lenses much, maybe you should take both bodies. But then again you have not listed any shooting scenarios where there'd be much fast moving action.
07-22-2010, 04:43 AM   #3
Ira
I never heard of anyone loathing the K-x's WB (especially with RAW), or anyone loathing an LCD.
So if you think the K7 takes better pictures for your style, why the question? You answered it yourself.
07-22-2010, 06:07 AM   #4
Where did you get this from??
I wouldn't worry about WB, I use my K-m with Auto WB 90% of the time without any issues, K-x supposed to have better AWB. By the way, shoot RAW and problem solved.
07-22-2010, 06:14 AM   #5
I didn't know the k-x had white balance problems. I have owned one since January, and on the contrary I think the white balance is exceptional. I like it much better than the canon 550D that I returned shortly after Christmas. I have found the only time I have a problem with white balance is when there are two different forms of light in the room (incadescent bulb and strong sunlight).
But as far as a travel camera...all I know is that since I put the Da 40 limited on my K-x it is so compact and fun to carry around. It feels like a large point and shoot. I don't have to worry about the lens getting banged up when I have the camera around my neck. I absolutely love that combination.
07-22-2010, 08:15 AM   #6
Regarding auto wb...Have you tried to use Kx in mixed light (for example a church with tungsten light mixed with daylight)? I can tell you the Kx sucks great time in Auto WB (at least compared witrh the K7, because I have never had any other DSLR)
Regarding LCD...IMHO, I don't think one would praise after handling a K7 or Nikon D90 or other camera with a 1 milion pixels LCD.
Anyway, thanks a lot for your interest and answers!
Probably I will go for the Kx since it seems more adapted to travel and street photography and try to shoot raw in difficult situations
Cheers!
07-22-2010, 08:38 AM   #7
Marc Sabatella's Avatar
Agreed - not sure you got the idea that the K-x was any worse about reading your mind with reagrd to WB than any other camera, but it just isn't true.
07-22-2010, 09:33 AM   #8
Ira
The K-x's Auto WB is only going to default to one of the presets--it doesn't read various color temperatures in a scene and give you a perfect setting.
Does any camera actually do that?
Just asking.
07-22-2010, 09:49 AM   #9
Whatever camera you've got, set it to auto white balance, shoot raw, and forget about it.
Well, look at it from the other direction. What would be the ADVANTAGE of taking a K-7? I gather you have a K-7 as well as a K-x although I don't think you actually said this. Anyway, what does the K-7 give you that you need on vacation? Two e-dials? Nah. Weather-sealing, well, maybe, but probably not. And which camera would you rather lose or have stolen while traveling?
I recently returned from vacation in Yellowstone National Park here in the US of A. For years I've been lugging my Pentax DSLRs, at least one, with a selection of lenses. Hiking to the bottom of Grand Canyon last December, after some agonizing, I decided I could live without the battery grip, but I still carried a K20D and a couple of lenses (one of which I' don't think I ended up using at all). Got some great photos but, well, hike to the bottom of Grand Canyon in a snowstorm with a K20D in your pack and you'll get a real good sense of just how much stuff weighs. Anyway for my recent vacation I decided to leave the really good equipment at home and take a couple of good Panasonic compact cameras. Worked out fine.
Will
(photo below taken with Panasonic FZ35)
07-22-2010, 11:20 AM   #10
thanks all for replies. I still stand by my opinion regarding my Kx auto WB because I've seen it in comparison to my K7 (yes, I have them both)
I hardly think this would come as a surprise since the K7 has a separate sensor for WB and boy, it is working wonders.
Will upload some test shots in the near future, stand by
07-22-2010, 12:35 PM   #11
Ira
The consensus of everyone here is that you couldn't be more wrong about the K-x's AWB.
And you still want to belabor this point?
I won't be standing by.
07-22-2010, 01:23 PM   #12
I'd say whatever difference you are seeing must be in some camera setting - Bright versus Natural mode, a customization that has been dialed in to the AWB or to the specific Picture mode you are using, or the option to do to the more versus less aggressive correction for tungsten light.
I believe you are mistaken on this. What the K-7 has a sensor to detect the light color and adjust *focus* accordingly, but this shoudln't to my knowledge have any effect at all on the WB of the camera.
07-22-2010, 01:38 PM   #13
Looks like fella's mind was already made up. Not quite sure why he even bothered to ask. Craving external confirmation?
camera, card, k7, kx, kx or k7, pentax help, photography, travel, wb
Travel Gene Temple Photographic Technique 18 04-23-2010 02:29 AM
Travel lens(es) rieux Troubleshooting and Beginner Help 28 02-09-2010 06:28 PM
Lens for travel robma47 Troubleshooting and Beginner Help 2 02-02-2010 12:24 AM
Travel Kit Help shiestmiester Pentax Camera and Field Accessories 1 02-27-2009 01:39 AM
Travel Kit. Mallee Boy Pentax SLR Lens Discussion 23 07-11-2008 03:57 PM
All times are GMT -7. The time now is 10:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
