Originally posted by gut1kor I think I did something stupid while changing the lenses. Now I see a lot of dust on my k-x sensor and it is so horrible. I tried dust removal several times but it did not go away. After some time, if I check the dust again, i see a lot of it.
How can I get rid of this? should i take it to service centre?
You might post a picture to demonstrate the problem you're seeing.
You should have a sensor cleaning blower and try that, although I find that sometimes wiping with a brush or swap is necessary. There are products for that purpose that are not terribly expensive. If things are really bad you may need a liquid cleaning solution, although again you need to purchase one specifically made for the purpose.
You absolutely should not take the camera to a service center, since you may ind yourself having to clean the sensor almost daily under some circumstances.
I found that on my K100 I needed the liquid solution occasionally, but so far the brush has sufficed on the K200. That might have been somewhat due to the K200's dust removal feature, or just luck. But I have definitely need the brush/blower combo on the K200, even with the dust removal feature.
Paul
