07-25-2010, 12:58 PM   #1
netuser's Avatar
K-7 exposure dial not going down? Help please
Hi all
So, just notice right now that on M mode for instance, dialing the exposure dial UP (front dial/wheel to the right) it works perfectly. On the other way, going down (front dial/wheel to the left) it goes erratic like for instance 1/200 -> 1/100 -> 1/320 etc, instead of going always down
Dial is broken? (think so ) or is there something in the camera that makes this behaviour "normal"? (dialing left mainly makes the exposure go forward .... until 8000)
Urgent help needed!!!
Thanks ins advance
07-25-2010, 01:10 PM   #2
aleonx3's Avatar
QuoteOriginally posted by netuser Quote
Hi all
Thanks ins advance
Very likely you had bracketing on.... you should be fine once bracketing is off.
07-25-2010, 02:58 PM   #3
netuser's Avatar
Bracketing is/was off
07-25-2010, 03:00 PM   #4
SpecialK's Avatar
No, there is not.
07-25-2010, 04:57 PM   #5
Ex Finn.'s Avatar
Switch the functionality between front and rear dials in the menu. If it works from rear dial, you then have a problem.
07-25-2010, 11:26 PM   #6
Try the turning the Lens correction/aberration off. As well as the highlight/shadow correction. It's worth a try...
07-26-2010, 12:05 AM   #7
future_retro's Avatar
I have the exact same erratic behavior with my DX grip, that's really odd it's happening with the dials on the actual K7 though.
07-26-2010, 02:12 AM   #8
Lowell Goudge's Avatar
what is the condition of the camera battery?
I have found on the K7 that the exposure dial processing is a little eratic when the battery is low
07-26-2010, 11:20 AM   #9
netuser's Avatar
QuoteOriginally posted by hyperboost671 Quote
Quite "funny" but I had turned ON the highlight/shadow correction during the afternoon.....
The battery was not fresh but it's still the same and today the problem is gone.
What I did was to turn on and off after a complete RESET on the camera AND also I turned off the highlight/shadow correction.
After that and during today I tryied again the highlight/shadow correction and there was no problem (battery still the same)
One thing is sure, there is an issue .... with highlight/shadow correction, or battery that might occur again ...
THANKS ALL for the prompt replies
camera, exposure, front, instance, pentax help, photography
Sun Dial tpeace Monthly Photo Contests 2 01-10-2010 05:01 AM
What is your e-dial default? jjay Troubleshooting and Beginner Help 7 03-11-2009 10:37 PM
Can I change out the Exposure Compensation Dial? Catelin Troubleshooting and Beginner Help 2 02-09-2009 01:39 PM
GBH just a few-dial up warning borno Post Your Photos! 8 06-11-2008 03:12 AM
Night photography with K10D - High ISO short exposure VS Low ISO long exposure pw-pix Pentax DSLR Discussion 10 02-03-2008 01:37 AM
All times are GMT -7. The time now is 01:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
