Hi Graham, congrats on your purchase. Its a great camera, I'm sure you will love it as much as I do.
As to settings, I guess these are all down to personal preference. All I can do is tell you what settings I use and why.
I'm not sure why you would want to disable the AF with half press, the 18-55 has quick shift manual focus (I think the 50-200 does too?) so you can over ride the AF at any time. My old eyes aren't as sharp as they once were and I tend to trust the AF more than my vision for sharp focus.
I shoot mainly in raw, so the Jpeg exposure mode only affects the image I see on the rear screen.
I use Adobe RGB as a colour space, for the reason you mentioned, it makes more sense as I'm using adobe software (Photo-shot and Lightroom) as my main post processing tools.
I use the DNG raw format, as it purports to be a universal standard, and I think things like this should be encouraged, besides that fact that it works natively with the aforesaid Adobe products.
I shoot almost permanently in centre spot focus, focus, and recompose. I generally do the same with metering, either centre spot, or centre weighted. (depending on the scene, I may use full Multi segment metering) I have the Custom menu item 6 'Link AE to AF point set to ON. So that the metering is always set for what I'm focusing on. I would definitely not have shot a nighttime concert in Multi segment.
I rarely use program or green modes. Relying on full manual and the fabulous famous Green button to get the exposure close and allow me to tweak it. MTF seems to be a good choice to optimise the lens capabilities, but be aware that it will automatically move the aperture to something like the mid range of those kit lenses (with appropriate shutter speed) which may not be the setting you are after, for example, you may want a shallower depth of field for isolating a portraiture subject against a busy background, the mid range setting would not then be appropriate, a larger aperture would allow shallower DOF.
A little tip is to set the USER mode for, say, a sports setup (fast shutter speed, auto ISO, etc) and use this as your 'alternate' setting. If you are shooting street and PJ style stuff, you can have your camera appropriately set for this style, and then, if you come across a situation that needs fast shutter speed... just flick the dial to USER. It may be useful, it may not.
Personally for sports shooting, which I do a fair bit of, I use TAv. Getting fast action shots on a long lens (sigma 150-500) often sees a rapidly changing amount of light-fall on the lens and in the background. The auto ISO function is a great tool for getting the exposure right quickly.
I know this is a little off topic, but having fairly large hands, I find the battery grip to be invaluable in balancing the body and giving me something to grip. The ergonomics of the whole setup are outstanding.
There are thousands of other possible permutations within the menu. It's all about what works for you.
No doubt some others will want to offer advise and probably even take issue with what I've said. That's cool, Its all about what works.
Wayne
