08-11-2010, 02:52 PM   #16
boriscleto's Avatar
This site has a good rundown of P-TTL flashes.
The Definitive Guide - Pentax P-TTL Flash Comparison
As well as more info about P-TTL
Further P-TTL Information - Pentax P-TTL Flash Comparison
08-11-2010, 04:00 PM   #17
ChipB's Avatar
QuoteOriginally posted by jonhock Quote
eccs19 & Chip B,
Do you guys set it in "auto" mode and if so do you use the green auto or the red auto?
Interesting, I just picked up the flash and it was set to "TTL Auto"?? Not sure why - I simply pick red or green depending on distance and f-stop (DOF) wanted.
08-11-2010, 05:34 PM   #18
RioRico's Avatar
QuoteOriginally posted by Christopher M.W.T Quote
Is there any actual theoretical technical advantage of P-TTL over TTL?
The technical advantage comes with fill flash.
With P-TTL the cameras metering can evaluate the mix of natural light and flash from the pre flash and calculate the correct duration which should lead to correct exposure
Maybe it helps with fill, but it sucks with non-A-type lenses. All my previous TTL flash usage depended on it being actually TTL, Through-The-Lens, with the camera measuring the light that actually reaches the frame. P-TTL constantly over-exposes with non-A-type lenses, rendering the vast majority of my glass useless with flash. I see this as a MAJOR shortcoming of my K20D. My 1976 Argus-Chinon CR-3E SLR reads directly off the film; why can't newer cams read the sensor and adjust accordingly? This is one reason I hardly ever use my not-inexpensive AF360 flash. Good thing I prefer ambient light.
08-11-2010, 06:25 PM   #19
mattdm's Avatar
Maybe it helps with fill, but it sucks with non-A-type lenses. All my previous TTL flash usage depended on it being actually TTL, Through-The-Lens, with the camera measuring the light that actually reaches the frame. P-TTL constantly over-exposes with non-A-type lenses, rendering the vast majority of my glass useless with flash..
It's not that it's over-exposing because it's getting things wrong. It's over-exposing because it's just firing at full power because the camera sees that it can't set the lens aperture and then goes all dumb in response.
Allegedly, the difference in reflectance of film and a digital sensor makes it problematic. Not sure I buy this, but that's the official line from pretty much all of the camera brands.
08-11-2010, 08:31 PM   #20
jonhock's Avatar
Alrighty then,
Thank you eccs19, I know that B&H has a Transend 4gb class 10 for $14.97 but now I believe I'll look around at the class 4sss and 6sss in an 8gb card.:ugh:
Green mode sounds good. Is that close to the green button?
I see a couple k10/20D users here. Have any of you had any experience with third-party battery grips?
You guys are helping me quite a bit, and I DO appreciate the input!
Last edited by jonhock; 08-11-2010 at 09:06 PM. Reason: another question please....
08-12-2010, 03:47 AM   #21
Lowell Goudge's Avatar
QuoteOriginally posted by mattdm Quote
exactly right, p-ttl needs to know the maximum aperture so that it can evaluate the flash intensity of the preflash when it meters wide open, so if there are no aperture contacts,it goes into manual mode. mowt _pttl flashes have no other option but full power
I don't buy it at all, the real issue is the additional sensor and input channel cost money.
TTL works as it should on my *istD, and the difference in reflectance is something the camera can calibrate out and not all films are the same so ttl would be more variable on film than with digital, since once calibrated you never change the sensor do you.
camera, p-ttl, pentax, pentax help, photography, ttl
Difference between TTL and P-TTL flash. rod_grant Pentax DSLR Discussion 46 11-15-2017 10:05 PM
P-TTL vs Canon E-TTL Taikonaut Troubleshooting and Beginner Help 2 04-22-2009 07:28 PM
P-TTL _AND_ C-TTL flashes? Zewrak Flashes, Lighting, and Studio 9 07-31-2008 03:36 AM
P-TTL VS TTL.... what is the difference to the average user? slip Pentax DSLR Discussion 16 01-17-2007 12:22 PM
All times are GMT -7. The time now is 06:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
