08-30-2010, 03:50 AM   #16
Pentaxor's Avatar
QuoteOriginally posted by JeffJS Quote
Then we've failed to do our job, which is to have you buying many many very expensive lenses...
classic.
01-30-2011, 12:16 AM   #17
QuoteOriginally posted by dgaies Quote
I had a Sigma 24mm Super-Wide that had the same exact issue. I ended up removing the three screws and the guard altogether and everything worked fine. In order to relocate it, you would have to drill and tap three new holes in the lens itself. That might be harder than just cutting the guard itself off (or just removing the ring/guard entirely).
I'm so glad that I found this post.
Similar lens (28mm mini-wide) - same issue.
Contemplating removing the 3 screws & ring/guard (not brave enough to attempt to grind the plastic sticking out bit) - could someone please advise as to the 'purpose' of the ring, and any possible consequences to its removal?
Many thanks
01-30-2011, 07:06 AM   #18
Remove the ring/guard (the little screws), then cut the tab off. You should be able to cut the guard with most any small saw and some sandpaper to smooth it. Don't cut this while it is mounted to the lens. Don't get dust/debris into the lens. Put the ring back on. I'd think that removing the ring/guard completely would lower the resale value of the lens.
The guard is there to protect the tab that stops the aperture down. That tab could get bent if the lens is set down too hard (without the cap).
02-01-2011, 08:59 AM   #19
Great thread...I was having a similar problem...thanks!
camera, lens, pentax help, photography
K-x lens mount with old k-mount lenses sipper Troubleshooting and Beginner Help 9 03-18-2010 05:45 PM
Lens mount can use with Pentax mount espanola Pentax SLR Lens Discussion 13 02-24-2010 04:48 PM
max lens mount/tripod mount weight soycory Pentax DSLR Discussion 1 10-28-2009 12:38 PM
Is it possible to mount an old CCTV C mount lens to my k20d? WiseOx Pentax SLR Lens Discussion 2 07-15-2009 03:01 PM
Change vivitar FD mount lens to K mount? meszidik Pentax SLR Lens Discussion 4 09-12-2008 09:59 AM
All times are GMT -7. The time now is 08:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
