Originally posted by rad291 Thanks. I'll try that when I get home.
THoog, That did work. I now understand what manual iso is. And when that choice was made, the standby display does show "M" in the upper left hand corner, instead of "AV." However, after making that change, I still am unable to use the aperture ring. If I change the ISO setting up or down that does change the picture that is taken, of course; but the picture taken does not approach what I can take by using the aperture. So, the use of the lens is still limited to only the focus ring. But, if I unlock the lens, and back it off counteclockwise while looking at the aperture through the lens to the point of the smallest (F22) aperture, then, Oh My! the lens functions like a fully manual lens, with control of both aperture and focus, and takes wonderful pictures (but with the disadvantage that the lens is not locked on to the camera - no other apparent problems though). Doesn't make sense that I can "kludge" a working solution that is not built into the camera. Also, I'm not sure why this actually works. Any thoughts?
