08-19-2010, 03:25 AM   #1
Should I buy a UV filter?
Hi,
I am planning to go travel at the Pyrenees mountains in a couple of weeks. I was wondering whether to buy a UV filter for my K-x or not.
I've understood that UV light is more common in higher areas so I think it may help there. Is there any other advantage of it? Are there any disadvantages?
Is shooting with a UV filter different than without?
Can you recommend on some manufacturers / models?
Thanks,
Yotam
08-19-2010, 03:47 AM   #2
blende8's Avatar
Filters are known to induce flare.
IF you want to use a filter, buy a very good one.
Possibly also a light yellow filter might work.
Also try a polarizer.
08-19-2010, 06:00 AM   #3
UV filters = flare magnets, imo, nevertheless they offer protection for your lens, that's why I often use the hood.
rather get a polarizer,
08-19-2010, 07:46 AM   #4
PEG Moderator
Kerrowdown's Avatar
I only use UV filter in the harshest of conditions for protection only, like blowing sand, otherwise run naked and use a lens hood for front end element protection.
The introduction of another layer of glass / plastic in front of the lens could possibly degrade your image. You nearly always adjust in PP what the UV filter used to do in the old film days.
08-19-2010, 08:30 AM   #5
R.Miller's Avatar
I only use a circular polarizer or GND filter. I figure why put some cheap glass in front of my expensive glass. For protection I use the lens hoods.
08-19-2010, 08:44 AM   #6
Marc Sabatella's Avatar
Whether or not there is more UV light at higher elevations doesn't matter unless someone can produce evidence that having too much UV light in your choice causes problems. Anyhow, I've shot at over 14,000 feet (4300 meters) with no filters can't say that UV light caused any issues; not sure how high you'll be.
08-19-2010, 08:44 AM   #7
QuoteOriginally posted by R.Miller Quote
I concur.
08-19-2010, 11:23 AM   #8
Its more dependable than the Atomic Clock that there will be a point/counter-point thread on UV/protection filters every 6 weeks.
08-19-2010, 11:54 AM   #9
RioRico's Avatar
QuoteOriginally posted by imtheguy Quote
I make it every 3 weeks, maximum.
UV-block filters protect the paychecks of those selling them, and nobody else. With the rarest exceptions, the layers atop digital sensors block UV light. Film is sensitive to UV; digital is sensitive to IR, and again with the rarest exceptions, IR-blocking "hot filters" sit atop all digital sensors. If you'll be in an environment of airborne sand & dirt & dust, of swirling mud & blood & beer, use a clear glass filter. Otherwise don't.
Useful filters:
* Clear glass, but only when it would be madness NOT to use it
* PL (polarizer), CPL (circular PL), to reduce glare and reflections, and enhance sky contrast
--- Two CPL's, or a PL+CPL, make a variable ND filter
* ND (neutral density), to slow-down the shutter
* GND (graduated ND), for shooting a bright sky over a dark foreground, etc
* Split-diopter, to appear to extend the DOF (half is magnified, half ain't)
Specialized filters:
* Yellow, for glaring colored neon lights at night
* Red, for enhanced detail in B&W shooting
* Blue or Violet, to emulate earliest photographic emulstions
* IR (InfraRed-pass), for shooting mysterious spectra
All other filtration AFAIK can be done digitally, in-camera or in PP.
08-19-2010, 12:16 PM   #10
I can accept everything except on an item I end up adding every 3-6 weeks on these threads. I shoot 99% of the time, every single day, within 50' of salt water be it ocean or calm canal. With no blowing sand in the marsh, I still use high quality Hoya UV/Protection and CPL filters that have obvious pitted coatings after less than a dozen outings and a couple cleanings of salt water film. I will happily give up whatever IQ you judge to keep my DA*300/4 front element from looking like the filters. Again, this is NOT a blowing sand issue, no breaking waves, no boating, just walking along the banks.
But nobody should make up somebody else's mind. You research, then try it yourself, then decide where truth fits with your requirements. Am I protecting paychecks or front elements? Beats the hell outta me.
08-19-2010, 01:40 PM   #11
thanks guys, I guess I don't need a UV filter. I'll get a hood and maybe a polarizer...
08-19-2010, 02:14 PM   #12
While this is true, the question posed in this thread is of a different sort than most - not someone wondering whether they should use a UV filter for protection, but wondering whether shooting high altitude might be a reason to actually use a UV filter for UV purposes. That's not a question that comes up very often at all, and I don't know that I've ever seen any sort of real discussion of that.
08-19-2010, 02:56 PM   #13
Agreed. But none of use could allow the general theme to go by unscathed
Best of luck Yotam with finding some great shots and I hope to see a few posted!
08-19-2010, 11:33 PM   #14
Thanks imtheguy, I hope I will get some nice shots. I don't have the time to practice before that travel so these gonna be my very first shots with my first DSLR...
08-22-2010, 05:44 PM   #15
FWIW.
camera, filter, pentax help, photography, uv
Pentax SMC FA 50mm/F1,4 to buy or not to buy? Eugene-S Pentax SLR Lens Discussion 22 12-05-2010 02:04 PM
Should I be a good Pentax choirboy and buy a DA 15 Limited or buy the Sigma 10-20mm? tokyoso Pentax SLR Lens Discussion 42 03-14-2010 04:54 PM
SIGMA 70-200mm f/2.8 II EX DG APO Macro HSM Lens for PENTAX:To buy or not to buy? thelittlecar Pentax SLR Lens Discussion 21 12-31-2009 06:01 AM
LBA help! buy 17-70 or sell the 70-300 and buy 18-250 cardikat Pentax SLR Lens Discussion 11 12-30-2009 03:55 AM
Where do you buy the ND 400 filter? raider Pentax Camera and Field Accessories 10 02-25-2009 01:07 PM
All times are GMT -7. The time now is 03:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
