07-28-2008, 12:42 PM   #16
Canada_Rockies's Avatar
M 100 f/4 "Dental" Macro
You fail to mention the SMC-M 100 mmF4 macro lens.
Although it is manual focus, (but with macto who cares, you focus on what you want anyway) it works very well.
The lens has the ability to extend the elements 50 mm(1/2 life size) without extension tubes, and at 100 mm gives you a little better working distance with the subject.
I actually couple mine to the 1.7x AF TC and get combination of autofocus plus effective focal length of 170 mm.
I just posted this shot taken with the SMC-P M 100mm f/4 "dental" macro in the M Club thread.
https://www.pentaxforums.com/forums/303297-post391.html
07-29-2008, 03:44 AM   #17
RollsUp's Avatar
QuoteOriginally posted by Peter Zack Quote
Another resource for info on some of these parts is found here:
Pentax Close-up Accessories
You might want to fix this link. I got an Error 404 - Not Found when I clicked on it.
07-29-2008, 06:17 AM   #18
Moderator Emeritus
Strange, here it is here:
07-29-2008, 08:48 AM   #19
Otis Memorial Pentaxian
The thread he created has morfed...
Maybe I should include this on the wrong word thread?
(Morphing into hulking troll...)
07-29-2008, 10:36 AM   #20
Moderator Emeritus
you caught me!! As soon as I posted that thread I realized all the thousands of misused words and spelling or grammatical errors I have committed over the years. if you live in a glass house....
08-03-2008, 07:32 AM   #21
Zou
Magnification
According to the April 2007 Pentax accessories brochure I have to hand, the following magnifications can be had using the FA 50mm f1.4:
With Helicoid extension ring, from 0.51x through to 1.04x (lens mounted normal way round), and from 1.16x to 1.54x with lens mounted in reverse using adaptor.
With regular rings (#1=9.5mm, #2=19mm, #3=28.5mm) and FA 50mm f1.4 mounted normal way:
#1 - 0.33x
#2 - 0.52x
#3 or #1+#2 - 0.7x
#1 + #3 - 0.88x
#2 + #3 - 1.06x
With rings + reverse adaptor:
#1 + #2 - 1.19x
#1 + #3 - 1.38x
#2 + #3 - 1.56x
#1 + #2 + #3 - 1.74x
It doesn't give any closest focusing distances, is it safe to assume that pretty much all of these require the lens to be nearly touching the subject? Also, does anyone know of a similar chart/data for other lenses?
50mm, camera, extension, focus, lens, macro, pentax help, photography, screw, setup, thread, tripod, tubes
In answer to 'Greetings' justinr General Talk 0 07-12-2010 07:51 AM
Stupid question. Looking for stupid answer. dws1117 General Talk 22 11-05-2008 09:51 AM
another answer to another teleconverter question cwood Pentax SLR Lens Discussion 9 10-01-2008 03:38 PM
Answer This Question, Please. NLAlston Pentax SLR Lens Discussion 23 03-03-2007 05:54 AM
An Answer to a question and a question. granitic Pentax DSLR Discussion 5 02-23-2007 09:28 AM
All times are GMT -7. The time now is 11:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
