08-22-2010, 09:44 AM   #1
HELP, cant remove lens (K20d)
Hello, I have a Pentax K20d that I just purchased. My father has a Sears lens
F60-300mm Auto. M# 202.7368300 that went on very easy, but will not come off now.
I havent used a camera in over 15yrs.
About to take a cruise next weekend for my daughters sweet 16 birthday.
any help or a place to take it near houston to be fixed would be Greatly Appreciated.
Thank you
08-22-2010, 09:48 AM   #2
boriscleto's Avatar
You have fallen victim to the dread "Ricoh Pin". The pin has become stuck in the autofocus mechanism. If the aperture ring is set to the A position, turn the ring to a non A position, ie. 22. The pin may retract. On the camera make sure the MF/AF switch is set to MF. If the Ricoh pin retracts, like it does on some Vivtars, you may be able to remove the lens. If it doesn't it will have to be pried off the camera.
http://www.google.com/url?q=https://www.pentaxforums.com/forums/pentax-beginn...M62oc49VkpW9uw
All Right...I did it....Ricoh Pin Lens is STUCK! - PentaxForums.com
http://www.google.com/url?q=https://www.pentaxforums.com/forums/pentax-slr-le...77TMK1zIMfp4DQ
08-22-2010, 10:01 AM   #3
Add this one to the list before you do any prying.
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/109887-cant-remove-lens.html
Good luck..
08-22-2010, 10:21 AM   #4
Thanks for the help.
The feeler gauge and firm pressure was the trick.
Thank yall again.
08-22-2010, 05:42 PM   #5
GerryL's Avatar
Don't forget to remove the pin prior to remounting the said lens to avoid doing the same thing again.
08-23-2010, 10:41 PM   #6
I found that the ricoh pin on my vivitar 28/2.8 could be finagled past the AF screw by flipping the MF/AF switch, which pushed the pin back and thus you could move the lens past. I have since filed down the offending pin.
camera, help, lens, pentax help, photography
How bad if fungus on a lens? Easy to remove? shaolin95 Pentax SLR Lens Discussion 12 08-31-2012 07:42 AM
Can't remove a lens! BobbieNT Pentax SLR Lens Discussion 25 08-08-2010 04:06 PM
How do you remove the dust that cannot be remove by the blower? rustynail925 Pentax DSLR Discussion 3 07-31-2010 10:39 AM
Help - can't remove lens from my K2000 CSSLDR Pentax SLR Lens Discussion 13 04-13-2009 06:57 AM
Ok, how to remove screws from a Pentax-M lens?!? Isaac314 Pentax SLR Lens Discussion 0 10-24-2008 07:38 AM
All times are GMT -7. The time now is 12:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
