08-23-2010, 01:47 PM   #1
subeeds's Avatar
End cap size
I am the proud new owner of a 135mm Pentax prime lens. Only drawback is that is didn't come with a lens cap or end cap. I know I need a 49mm lens cap. Would the end cap be the same size?
08-23-2010, 02:04 PM   #2
KxBlaze's Avatar
QuoteOriginally posted by subeeds Quote
The mount cap is universal for all K-mount lenses. Unless that lens is a M42 lens you will be fine with any mount cap that is made for Pentax K mount.
08-23-2010, 02:20 PM   #3
subeeds's Avatar
Thanks, KxBlaze. I just wanted to be sure before I got stuck with a bunch of useless stuff.
08-23-2010, 02:48 PM   #4
Pentax however made two variants in k rear end caps. You will find that the rim around the base of the cap is larger to cover the increasing number of contacts with A, F and so on.
The rear lens cap for K and M had a smaller rim, not much need to cover contacts there. Of course they still fit, but contacts are not fully covered with the older type if you fit it on a A, F, FA lens.
camera, cap, lens, pentax help, photography, size
Fisheye Takumar 17/4 lens cap size 58mm? barbosas Pentax SLR Lens Discussion 2 01-30-2010 11:38 AM
vivitar cap size? miks Pentax SLR Lens Discussion 5 12-27-2009 01:18 PM
Lost lens cap on 18-55mm DA L. Can anyone confirm if this eBay cap is the correct one philthy Pentax SLR Lens Discussion 3 10-15-2009 01:26 AM
Lens cap size/diameter for Auto Takumar 55/2 altair Pentax SLR Lens Discussion 6 06-27-2009 05:15 PM
All times are GMT -7. The time now is 09:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
