08-25-2010, 09:52 PM   #1
Dust Alert false positive?
Ok, i took my lens off today just to show someone the mirror, bad idea. I then got dust on my sensor, black spots on my photos, cant see on viewfinder, ect...
I ran Dust Alert and it showed MANY black specks, and one big splotch that definitely was not dust, i was worried because i thought some splash of moisture of some kind got onto the sensor.
I got home did dust alert once more, and the splotch was still there, so i set the camera on cleaning mode, blew off the sensor with a Giotto Q-Ball and ran the Dust Alert again. All of the black specs were gone, but the splotch was still there. I took some photos and there was nothing wrong with them, they looked fine, no splotch at all.
I ran Dust Alert 2 more times and after the second time the splotch stopped showing up.
What happened?
08-25-2010, 09:58 PM   #2
goddo31's Avatar
What were you pointing your camera at when taking the dust alert photo? What sort of light source?
08-25-2010, 10:02 PM   #3
QuoteOriginally posted by goddo31 Quote
Just pointing it at a well lit blank white wall. I tried some more Dust Alerts and the splotch has not returned, seems to be gone for good, but i would still wonder why this showed up in the first place
08-25-2010, 10:12 PM   #4
Put your cap on lens then Dust Alert.
08-25-2010, 10:40 PM   #5
QuoteOriginally posted by Danny Delcambre Quote
Direct from the instructions:
From page 286
Fully display a white wall or uniformly bright subject in the viewfinder and press the shutter release button fully
08-25-2010, 10:41 PM   #6
MoiVous's Avatar
Dust alert can give a false positive if there is any object/shadow in the image. I've found that even a cornice or wall edge can create artefacts.
Whatever you use as a blank light coloured surface (not a lens cap!!!) - it must be a completely blank untextured surface. One of the camera store techs I know uses his computer monitor with a pure white background only visible (he has a file for the purpose) - making sure that none of the screen edges are visible.
Cheers
08-25-2010, 10:45 PM   #7
goddo31's Avatar
QuoteOriginally posted by MoiVous Quote
Cheers
+1, exactly.
camera, dust, pentax help, photography, photos, sensor
Pentax K-7 Dust Alert and Dust Removal Functions brosen Pentax DSLR Discussion 9 02-09-2016 04:43 AM
Dust Alert chris9486 Pentax DSLR Discussion 3 01-24-2010 04:19 AM
dust alert houstonmacgregor Pentax DSLR Discussion 0 07-10-2009 07:51 AM
Dust Alert audiobomber Pentax DSLR Discussion 2 10-19-2008 02:16 PM
K20D Dust Alert Wheatfield Pentax DSLR Discussion 3 05-18-2008 03:52 PM
All times are GMT -7. The time now is 10:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
