Originally posted by mikro Looking for a good list of setting changes if any need to be made to get the most out of this camera. Should I be using the Highlight Correction in camera or is it best to just take care of it in PP? Any other setting changes you've found to get improved IQ from the K7?
I've had one for over a year. It's a great camera.
Highlight correct is decent when you need it, but it does come at the expense of added noise and a little bit of color-flatness. I never use shadow correction if there will be people in the scene, because it seems to do weird stuff to skin tones — for fixing that, it's all about pp.
Use the "natural" mode rather than "bright", especially if there's any bright reds or oranges in the scene — bright tends to blow that channel. And it's also a bad choice to use indoors, where artificial lighting makes it do weird things to blue pigments. Natural really is the way. It's a little more subtle than what people are used to seeing with in digital camera output, but that's not a bad thing. (I turn the saturation down a notch further, and usually increase contrast one step. But that's my own personal preference.)
The auto white balance is
excellent. I almost never switch from that.
I leave the distortion and chromatic aberration correction on almost all of the time, even when shooting with nice lenses. But if you want a fast burst rate, turn it off. (And if you like to chimp, it'll be super annoying.)
And, now that I can't get memory cards smaller than 4GB easily, I shoot RAW+. I generally use the JPEGs, but shooting the RAW files too gives me the option.
