Originally posted by JeffJS And there is nothing in focus in your keyboard shot. It's all well and good to say you can get close with the 18-55 kit lens but it still, is not a macro lens.
The L and M are in focus, it's just that depth of field is very shallow, there looks to be a little blur from shake and the photo is underexposed. Hcarvalhoalves, the ideal way to achieve closest focus is to set the focus to manual and move the camera back and forth until what you want is in perfect focus.
JeffJS, the 18-55 is not a macro lens as far as you're concerned. I wouldn't call it a macro lens either, but it would be called a macro lens if it were branded Tamron or Sigma. A lot of people consider photos of flower heads to be macros, and the 18-55 is highly capable of capturing those. An argument about the definition of "macro" is rather pointless. I'd like to see the definition of a macro lens reserved for lenses that do 1:1, but that's just my opinion, it doesn't reflect reality. Lots of people think it should be 1:2, but that's just an opinion too, probably because the older Pentax macros were only 1:2. The current Pentax macro lenses are all 1:1. The difference between 1:3 and 1:2 is meh, no big deal. The difference between 1:1 and 1:2 is a much bigger deal.
In the end, it's about how much magnification you achieve, and how to compare. Saying a compact camera can focus at 6 cm doesn't say anything about its suitability for macro or its magnification. Most compacts use digital zoom for super macro, which is just in-camera cropping. I believe the K-x and 18-55mm can achieve higher quality macros than the compact, but the OP is in the best position to demonstrate. If he wants to shoot flowers, the kit lens is fine. If he wants to fill the frame with an insect, he'll need to look at another solution.
