08-29-2010, 12:58 PM   #1
Tamron Adaptall question
Hi all,
I have an original Adaptall P/KA mount which doesn't seem to have any glue on the screw. However when I use it to attach a Tamron 80-200mm macro on my K10D there are two problems: 1/ The aperture value is not read and thus not adjustable, and 2/ It's extremely stiff to manually turn the aperture ring (the blades do close & open though).
What should I do?
Thank you.
08-29-2010, 02:27 PM   #2
The aperture has to be set manually using the aperture ring, since there are no electrical contacts on the lens. You camera furthermore has to be in M mode. Here's is an article on how to use manual lenses with Pentax DSLRs: https://www.pentaxforums.com/forums/pentax-lens-articles/110657-how-use-manua...7-k-x-etc.html
To answer question #2: I think that through routine use, the ring will loosen up. This was the case with on of my older lenses as well.
08-29-2010, 04:27 PM   #3
QuoteOriginally posted by binh.nguyen Quote
Hi all,
What should I do?
Thank you.
Hi,
Whether you see glue on the contacts or not, just take a small exacto knife and scratch the first contact, left of the three ball bearing like protrusions on the mount. I did that with every mount I have acquired so far and they all work as they should. Before you mount the adapter check to see if the aperture ring moves on the lens freely or not. If it's stiff try rotating the aperture ring gently back and forth and see if the movement becomes more smoother. When mounting the adapter to the lens, turn the aperture ring on the lens to it's widest position, align the green dots, make sure the two tabs on the mount is correctly placed in the slots of your lens and mount. After mounting inspect the rear of the lens mount, check to see if the aperture actuating pin is bent or not. If it's bent straighten it out carefully then try moving the pin and let go, you should feel some resistance when pulled and it should snap back to it's original position with an audible snap. If these steps are followed, you should be able to get AE control on your Tamron lens,
Good luck,
adaptall, aperture, camera, pentax help, photography, tamron, tamron adaptall
Tamron Adaptall question Glacian22 Pentax SLR Lens Discussion 10 07-15-2010 05:42 PM
Tamron Adaptall 2 question iClick Pentax SLR Lens Discussion 6 06-05-2010 09:57 PM
Tamron Adaptall-2 Mount Question rayallen Pentax SLR Lens Discussion 7 04-28-2009 04:37 PM
Tamron Adaptall Lens Question Paulypentax Pentax SLR Lens Discussion 2 02-19-2009 06:46 PM
All times are GMT -7. The time now is 03:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
