08-30-2010, 10:15 AM   #1
Remove Author name
Solved.
I have a K-x.
I made a spelling error in the Author setting and cannot remove my name in order to redo it.
How can I correct my mistake?
08-30-2010, 12:10 PM   #2
Accross all your photos? You'll need to open up each one and change the EXIF data manually, as the setting in your camera is not retroactive.
08-30-2010, 12:18 PM   #3
TWN
Thanks for the reply but I fixed it myself.
I just had to read the instructions over and over and over for the information to finally sink in
10-26-2012, 01:30 AM   #4
I know this will be like banging the thread, but I would like to know how you solved. Because, I have also recently bought a 2nd hand Pentax DSLR and it shows the previous author's name in each photo.
Thank you in advance!
10-26-2012, 04:03 AM   #5
QuoteOriginally posted by BARAnCUDA Quote
For my K-r, I found it in the menu under Copyright Information. It is probably the same for your K-x. If you have the manual, the page for Copyright Information should be listed in the index section in the back.
Tim
10-26-2012, 08:10 AM   #6
QuoteOriginally posted by atupdate Quote
Tim
Great, found and managed to modify it! Thanks for the ultra quick answer ;-)
10-26-2012, 09:08 AM   #7
Just1MoreDave's Avatar
The copyright information is not reset even if you reset all the settings to default (two operations in newer cameras like the K-r). I think you have to go to the copyright screen to delete the old information and reset it.
10-26-2012, 09:30 AM   #8
QuoteOriginally posted by Just1MoreDave Quote
Thanks, but I had already managed to change it thanks to the answer of atupdate
author, camera, name, pentax help, photography
How do you remove the dust that cannot be remove by the blower? rustynail925 Pentax DSLR Discussion 3 07-31-2010 10:39 AM
Another Author Photo sjwoo Photographic Technique 11 03-30-2010 06:23 PM
A beautiful female author (NSFW) tony119 Post Your Photos! 14 04-12-2009 06:04 PM
Author Headshots for Dustjacket. MJB DIGITAL Photographic Technique 0 09-01-2008 01:41 PM
Exifer (EXIF author copyright) jorgemarmo@K100D Digital Processing, Software, and Printing 16 02-07-2008 06:44 AM
All times are GMT -7. The time now is 10:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
