09-03-2010, 03:52 AM   #1
I'm out of my depth !
Hello, I got my Pentax *ist DS today and somewhat bewildered. My other camera has a fixed lens so now with the pentax I had a play and I'm just a little confused.
At first It woudn't take a shot at all, then I noticed a lock button on the lens, so I flick that and now it works but still not getting the shots I thought I would get.
So what I'm after is a manual for the lens. I've looked on the web, and usually the web has thousands of results, not this time.
so heres the lens info; Sigma DC 18-125mm 1:3.5-5.6
Even the Sigma website isn't much help, they have a similar lens the F starts at 3.8 where as mine starts at 3.5 so I'm some what lost, I have many things to learn......and I'm willing !
Thank you for any help.
09-03-2010, 05:05 AM   #2
Ira
If you have the manual for the camera, you really don't need a manual for the lens:
Does it have an M/A button on it? If so, put it on A for Autofocus.
That's about all you have to do for a lens.
09-03-2010, 05:26 AM   #3
Lowell Goudge's Avatar
If I were to guess, it sounds like the OP has a lens with an aperture ring, and an A position, which he has interpreted as a "lock"
I would be willing to bet that the camera does not have the use aperture ring function set, and it is easy to press the A button on a lens when installing it, taking it out of A mode.
That should be the only button on the lens, other than perhaps a zoom lock to overcome zoom creep when walking around.
I don't know Sigma lenses with this function but my tamron 28-75 has this feature but it only inhibits zoom, not any camera function. Perhaps a sigma lens owner can advise whether this lock, if it exists, disables the lens when set?
09-03-2010, 06:00 AM   #4
Zav
Zav's Avatar
Isn't this a zoom lock switch which prevents zoom creeping? Try to engage this lock then zoom. If you can't zoom, well, it is it!
09-03-2010, 08:28 AM   #5
MRRiley's Avatar
QuoteOriginally posted by TeamPentax Quote
Tell ya what. take a photo of the lens where the "lock" button is and post it here. That may help clear up the question a bit and make it easier to stear you in the right direction.
Mike
09-03-2010, 08:42 AM   #6
The Lock button on the lens probably locks the zoom at some point. There are several different versions of this lens but I think this is the one he has.
ebay link deleted
Sorry about that. That's what I get for not checking my typing in Google..
http://www.photodo.com/topic_42.html
09-03-2010, 09:58 AM   #7
Jeff
on that lens the only "button" I see is the interlock to release the lens from A mode.
AS I pointed out in my initial post, if th elens is not in "A" mode, then the camera may not work if the "use aperture ring" option is not selected.
I have a gut feeling this is the real issue, because I cannot see a Zoom lock being electrically interlocked with the camera to inhibit all functions.
09-03-2010, 10:47 AM   #8
Marc Sabatella's Avatar
The lens linked is a 28-105. The OP mentioned an 18-25. Different lens.
Lock issue aside, I agree with Ira that even when he gets that sorted, he really is gong to need a manual for the camera. And actually, not so much a manual (he might have that), but something designed to actually teach you how to use the camera. I gather the various aftermarket books like the Magic Lantern guides are good for that sort of thing.
09-03-2010, 12:16 PM   #9
I've fixed my original post.. The lock I'm referring to can be seen near the lens mount to the left of where it says Sigma.
Lowell, I agree, and did earlier with your original post.. When I first got my K10d (my first ever dSLR) I was quite disheartened to find that I couldn't use the collection of manual lenses I had amassed waiting for the K10d to be released. That is, Until I read the manual.
09-03-2010, 06:55 PM   #10
Thank you so much for all your help, I was, I mean a complete newbie, I figure its like a zoom lock, I can't zoom it while its in the lock position so that answers that.
The other thing which I feel like a bit of tool for admitting but I couldn't figure out how to zoom, after some toying with it I realized that the zoom works in the opposite direction.... My olther camera (Fuji S9500) zoom works in the other direction and I've been using that for 5 years so it was natural for me to use the lens in the same way, like it was instinct, I've figured it out now but thank you so much, I really appreciate all your comments.
09-08-2010, 03:48 AM   #11
Thanks JeffJS, thats the one .
camera, lens, pentax, pentax help, photography, sigma, web
Shallow Depth of Field sjwoo Photographic Technique 34 04-07-2010 11:24 PM
depth of field miss_alexx Troubleshooting and Beginner Help 20 12-11-2009 10:56 PM
depth of field rattrap Troubleshooting and Beginner Help 9 10-28-2009 11:20 PM
calculating the depth of field rustynail925 Troubleshooting and Beginner Help 18 10-06-2009 05:31 AM
depth of field dafiryde Pentax SLR Lens Discussion 4 11-05-2008 01:21 PM
All times are GMT -7. The time now is 06:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
