09-06-2010, 04:58 PM   #1
mrjamesabels's Avatar
I need advice on Macro lens purchase.
I currently use a Vivitar Macro TC with a 50mm f1.4 Smc-A and I've taken some very nice pics so far with it. My problem is the focus plane is too thin. I want more of the object to be in focus. I take pictures of flowers, bugs, vegetables and anything interesting. I would like it to be inexpensive as I don't make money from photography and some lenes are really expensive! What focal length should I look for and why? Can I get more focus depth with my TC? I have reverse mounts, a TC and extension tubes as well. I'm looking to spend up to $300. Some examples-
09-06-2010, 05:01 PM   #2
yeatzee's Avatar
QuoteOriginally posted by mrjamesabels Quote
Why post such small thumbnails?
Anyways, if more DOF is what you want may I ask what aperture you normally shoot at for macro's? Have you ever tried stacking?
09-06-2010, 05:12 PM   #3
How would I stack? f10 ? I stop down as far as I can but the light gets low. Also, why can't my viewfinder show accurate DOF???
09-06-2010, 05:12 PM   #4
I won't comment much on technique other than to say, the closer you are to your subject, the more shallow your DOF will be. That's photographic truth and there is no getting around it (in a single shot) other than to stop the lens down, or pull back and crop. That's true of any lens, in any situation. The combo you have is a very nice one. You can get dedicated 100mm macros in your budget, there are a couple M100mm f4 (1:2 macro) lenses for sale right now over in the marketplace. However, your results in the same situations are going to be about, the same.
09-06-2010, 05:15 PM   #5
Set your camera to M, and use Optical Preview, and it will (but like other DOF previews, it's going to be darker as you stop the lens down). It doesn't show it naturally because the lens is held wide open as you focus. It only stops down at picture snapping time.
09-06-2010, 05:20 PM   #6
A ha! Thanks I didn't know that about the aperture being wide open til snapping time. So a 100mm should do the trick!
09-06-2010, 05:28 PM   #7
That's what you're using with your 50 and vivitar combo so I assumed that's the range you were looking at. There are others available of course, both Pentax and Sigma offered 50mm macros that can be had reasonably. If you want to spend some cash and don't mind getting real close, the DA35 is a 1:1 macro lens as well. Sigma had a 70mm, 105mm, 180mm (find one of Those! but not for $300), Tamron a 90mm, etc. Or you could look at some of the work done around here with bellows, extension tubes, reversing adapters, and cobbled combos of all of them.
Stacking, unless I'm wrong, is taking multiple exposures each with a different part in sharp focus. Then combining them in post processing to make one sharp image. From what I've seen here, it works quite well though I've never tried it myself. The bugs always fly away before I get the second shot .
09-06-2010, 05:47 PM   #8
yeatzee's Avatar
The images are still small thumbnails.
It seems to me you need to work on your lighting setup first and foremost
Get a usable light setup using a flash so you can stop down more while keeping the IQ at its peak (in regards to shutter speed and ISO).
09-06-2010, 05:53 PM   #9
QuoteOriginally posted by yeatzee Quote
Click on the thumbnails in his second post.
09-06-2010, 06:52 PM   #10
yeatzee's Avatar
QuoteOriginally posted by JeffJS Quote
I have been... still small
09-06-2010, 06:56 PM   #11
Try this..
mrjamesabels's Album: Everything I Like - PentaxForums.com
09-06-2010, 07:15 PM   #12
yeatzee's Avatar
Thanks.
It appears the IQ is pretty bad in all shots but the first flower photo in your album.
advice on macro, camera, focus, macro, macro lens, pentax help, photography, tc
purchase advice: K-7? K-x? Wait? WMBP Pentax DSLR Discussion 19 03-09-2010 09:25 AM
Lens Purchase Advice krs Pentax SLR Lens Discussion 9 12-10-2008 09:25 PM
HELP! In need of some advice on lens purchase Amy Pentax SLR Lens Discussion 3 03-13-2008 09:17 AM
Advice for a lens purchase - SMC M 50mm f1.4 esdy_11192 Pentax SLR Lens Discussion 4 12-17-2007 03:41 PM
Need advice on lens purchase George Lama Pentax SLR Lens Discussion 7 08-29-2007 09:54 PM
All times are GMT -7. The time now is 07:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
