Most have said it - but almost all current true macro lenses (not zooms with a pseudo macro function) are pin sharp and easy to handle - so +1 on that.
Originally posted by Digitalis I find using a longer Macro lens is very beneficial with insects, especially easily scared ones.
get something like a 200mm f/4 and some extension tubes. that ought to give you a decent working distance from your subject.
Personally I use the Sigma 180mm f/3.5 and Pentax FA*200mm f/4 ED macro lenses...which are highly regarded and offer the ultimate in image quality.
To get black backgrounds I keep a 8"X10" piece of black velvet in my camera bag. black velvet eats light and is useful for eliminating distracting backgrounds.
Sigma 180mm f/3.5
Digitalis makes an
important point - the longer the focal length, the greater the subject distance. Keep that in mind.
Originally posted by JeffJS The DFA macros are Pentax's latest and greatest and there is nothing wrong with them. In fact, if you Really want to spend the cash, a very good way to go. What I meant was that Pentax's earlier (A and M) 50mm macros are 1:2, half life sized. The DFAs are 1:1, full sized.
Once you get hooked on macro like Yeatzee and Rense you'll probably start using other kit (like the bellows you've got on order). But
be warned - some of the newer lenses
do not have an aperture ring (eg PENTAX-D FA 100mm F2.8 Macro WR) - so you can't control that at all
. And if you reverse it, same applies. Hence Jeff is not quite right there.
And as for flash - a macro maniacs best friend. Get one you can sync/slave off camera as you'll want to side light etc.
Then you'll want some other things like macro rails, reversing rings, ring flash (Digitalis has one he uses for things other than macro!).
Enjoy the adventure!
