Originally posted by JoepLX3 Making me lean towards the Metz 48 AF-1
Or should I go for the Sigma super?
- Did Sigma (and/or Pentax) address this assist beam compatibilty issue that is flashing on camera assist beam?
- Will I miss the bounce card of the Metz?
The Sigma ST is not comparable to the others, too compromised.
I have a Sigma 530 Super. I agree, the menus are confusing, but I've read more posts criticizing the Metz menus than I have the Sigmas', so I believe this should be added to the Metz list of cons in the P-TTL guide.
As Matt mentioned, a focus assist beam will not trigger the Sigma flash, it's only triggered by the strobing of the built-in flash on the older Pentaxes. I've also heard this can happen with the Pentax 540. I have a K20D, but it's not something that's affected me, because I've only used the flash off-camera where I had enough light to focus without AF assist.
Mlatour criticized the Sigma because it broke when it fell while mounted on the camera. I consider that a feature. I'd rather the flash break than my camera's hot shoe. It will not break in normal use.
The biggest difference to me with Sigma Super vs Metz 48 is power. Even the full power flashes like the Sigma run out of range sometimes. A bounce card is a nice feature. I wish the Sigma had one, but it's not as important as power.
The Metz 48 can't act as a controller. That's an issue if you ever intend to add another flash. With a Metz 48 now and a 58 later, you'd have the more powerful flash on the camera, and the weaker one in the umbrella; not ideal. A pair of Sigma 530 Supers is less costly than a Metz 48 + 58. Perhaps the new Metz 50 will be able to act as a controller? I believe there's also a problem with the sensor location on the Metz flashes that has been addressed in the newest versions (Not mentioned in the Definitive Guide?).
