09-13-2010, 04:15 PM   #1
mantis's Avatar
when the sky is bright
hey guys, i know that its a common issue and problem when doing scenery, but how do you allow the ground to be as bright as the sky? instead of just a silhouette?
09-13-2010, 04:19 PM   #2
You'd have to either do an HDR photo, combine two exposures manually, use use a neutral density filter or a polarizer. If both are properly exposed to begin with (usually accomplished using -1EV), you can also just fix up your exposure in photoshop.
09-13-2010, 04:22 PM   #3
future_retro's Avatar
Just using a regular lens and one exposure, you have to choose what to correctly expose, either the sky or the ground, the ground is easier to recover in photoshop, but if the sky is overexposed, then you can never get it back
when would you ever want to expose for the ground then? when photoshop annoys you
09-13-2010, 07:43 PM   #4
mantis's Avatar
so the best fix is, under expose the sky, so the ground is darker, and then brighten up the ground in ps?
09-13-2010, 07:58 PM   #5
No, properly expose the sky and then even it out is PS, if you properly expose the sky then the ground will be underexposed
09-13-2010, 08:34 PM   #6
RioRico's Avatar
The usual optical solution is a GND (graduated neutral-density) filter, where half is darkened and half ain't. Don't leave home without it.
09-13-2010, 08:44 PM   #7
mantis's Avatar
ive thought about these
so they do about the same huh? would you need different gnd filters? because what if its a different type of day and the filter doesnt work as it should? aka different lights from the sky?
09-15-2010, 03:21 AM   #8
RioRico's Avatar
QuoteOriginally posted by mantis Quote
Many sorts of GND filters exist. Here's the Wikipedia entry on GND's. The one I use came from an eBay grab-bag of filters, a French-made Chromofilter M2 which is fairly hard-edge with about two f-stops difference between opposite sides. I suppose if I found a Galen Rowell set, I'd think of ways to use them. Consider what could be done with a center-spot filter...
09-15-2010, 06:09 AM   #9
reeftool's Avatar
The filters mentioned are a good item to have but if you don't have them, you can get by simply with a slight under exposure. I spent this past Saturday at a large car show. It was bright sunshine in the middle of the day, probably the harshest light. I was using my 10-17 fisheye a lot as it is my widest and works quite well at an event like this which is crowded and you have to get very close to get any photos at all. I have no filters for this lens and I don't know of any. I got my best shots by setting the EV to -1 and stopping down to f/16 which helped with the lens flare. Remember that digital photos are free. Bracket your shots and see what works. Look at the shots on the LCD and if it is too bright to see, go by the histogram. Big peaks way to the right mean that you that you are overexposed. It was quite easy to adjust most of my shots in Elements by simply brightening up the shadows.
09-15-2010, 06:31 AM   #10
akanarya's Avatar
brilliant idea i think
camera, pentax help, photography, sky
Nature bright eyes. sara Post Your Photos! 6 06-06-2010 11:47 PM
More bright flowers Ash Post Your Photos! 17 08-31-2009 10:50 AM
What IS that bright thing? imtheguy Post Your Photos! 4 07-16-2009 08:50 AM
Landscape photo with Bright Sky Exp Suggestions mi2nc Photo Critique 6 11-01-2008 02:16 PM
Very bright in rather dark gawan Post Your Photos! 3 01-21-2008 06:02 PM
All times are GMT -7. The time now is 11:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
