Originally posted by Lowell Goudge There is no need to "take anything apart" all pentax DSLRs have a wired release using a 2mm 3 connection headphone plug. The reason for using a photo diode is because there is no need to supply current, the camera's shutter release circuit does this by way of a resistor in series with the release contact. It is looking for a short to the common to trip the shutter. As for functionality the scheme works and using a commercial plash slave (schematic shown above) it os possible to trip the shutter with a camera flash. To create a lightning trigger simply requires changing the base emitter resistor to reduce the current necessary to turn on the transistor i.e. To increase the sensitivity. Too many people are looking for a complex solution when using these three simple components is all that is needed
True , no need to take anything apart, I actually scabbed some parts from old photo gear and have added it to the shutter release cable , I can get it to fire one shot with just the photo diode & resistor attached with a flash, then it won't fire again ?
When I put in the transister it just trips the circut and it just continuously shoots so now my question is with all you very intelligent people joining in, what sort of resistor ? give me a code , they run in code from the colors on them, as I'm sure you all knew this 10 years ago which I only found out 3 days ago, and also the transistor, may be a code number to go for that to, I go into a electronics shop and explain to them what I'm trying to achive and then they look at me like "are you ET" so the staff in these shops usually can't count their elbows and get the same answer twice so getting their advice is pointless. I go look at the hundreds of trays containing just resistors and I'm like.....which one ?
As I've said I made it trip one photo with a off camera flash so I now know it can be done all I need is the right parts / ingredients.
Someone said I should use a IR diode, is that a better idea than a photo diode ?
Also is there a way I can put in a pot switch so I can change the sensitivity of the Diode on the run ? So if it misses a shot of lightning a can turn the pot and wait for another chance so I can set it up for what ever situation I might be in.
I only have the idea,, but the how to is beyond me.
if I can finally get a prototype up and running I'll do full sketches and even a youtube video so everyone that has the 2.5mm jack can make one without paying through the nose.
Yeah I know i could buy one, but wheres the fun in that ? I'd rather buy a lens, I only have the one !
I was thinking I could put a 2.5 mm jack onto the homebuilt shutter release then I can attach it as an accessory so I can use it when I want without having it on all the time.
Some say to put the diode on the eyecup so it see's what the camera see's, I like the hotshoe my self but what ever works best WINS !!!! I can make both, have 2 Diodes the ideas are endless, the knowledge... is hungry for more !
Thank you to everyone again for all your help, I really appreciate it and as I've said before, once completeted I'll put back in here so everyone can have a go, it's only held back by our imagination !
