09-15-2010, 06:51 PM   #16
mattdm's Avatar
QuoteOriginally posted by noblepa Quote
According to the manual at PentaxImaging.com, the longest flash duration of the AF540FGZ is 1/1200 second, far less than 1/250 second. So, if the shutter were capable of being fully open at 1/250 second, the 540 should be able to sync to it.
Paul, the Pentax flash manuals quote the T.5 flash duration. This is an industry-standard measurement with some practical use in comparing flashes, but not so much in terms of actual use. The flash pulse is a curve on, curve up, peak, curve down, off. The T.5 duration is the length of time for which the curve is over 50% of the peak power. There's quite a lot of light left before and after that.
Another standard number is the T.1 number (given by Metz in their manuals). This is the time the curve is above 10% of peak, and is more representative of the actual impact on the exposure. Normally, this is about 3 the T.5 time, but that's just a rule of thumb.
Pentax USA won't answer my queries about the T.1 flash times. I Pentax Japan just directs me back to Pentax USA. (I suspect Pentax USA can't answer, actually I don't think anyone at Pentax USA knows anything technical about their flash system beyond what can be found in the manual and whatever secret repair manual they have.)
Maybe one of these days I'm going to have to find someone with a digital oscilloscope hooked to the right sensors and measure myself.
09-16-2010, 06:18 AM   #17
Lowell Goudge's Avatar
QuoteOriginally posted by mattdm Quote
Paul, the Pentax flash manuals quote the T.5 flash duration. This is an industry-standard measurement with some practical use in comparing flashes, but not so much in terms of actual use. The flash pulse is a curve — on, curve up, peak, curve down, off. The T.5 duration is the length of time for which the curve is over 50% of the peak power. There's quite a lot of light left before and after that.
Pentax USA won't answer my queries about the T.1 flash times. I Pentax Japan just directs me back to Pentax USA. (I suspect Pentax USA can't answer, actually — I don't think anyone at Pentax USA knows anything technical about their flash system beyond what can be found in the manual and whatever secret repair manual they have.)
Matt
I have been considering the same approach to measure duration. One thing to consider, however, and I am thinking about this as I write, so forgive me if some of it seems disjointed, is that the flash pulse, or more appropriately either the current through the tube or the voltage applied to the tube is going to be a exponential. I will write the equation using spreadsheet formula notations, to make it clear
Value = exp(-t)
the value will be what ever dictates power in the flash during discharge, probably the current from the capacitor.
time constant t will be the discharge ov the capacitor through a current limiting resistor
As a result, if you have the time to half value, you should be able to predict the time to 0.1
There are a lot of assumptions here, that will cause errors such as the voltage across the tube as a function of current, which may cause additional errors, but in a first order, you should be close.
If we start with the guess that the time to 0.1 is 3 times the time to 0.5 then this would result ina duration of 1/400, or 2.5mS that is a substantial period in time, and would only allow a duration for each shutter curtain, leading and trailing of 1.25mS for the sweep. Now, this is something that could be measured. i.e. how fast a curtain travels across the sensor, using a repeating pattern on a scope, and photographing it.
camera, flash sync, pentax help, photography
Radio triggers and flash sync speed sash Flashes, Lighting, and Studio 11 02-20-2010 03:00 AM
Flash high speed sync. Deni Photographic Technique 22 08-26-2008 02:35 PM
Studio Flash Sync Speed for K10D fwbigd Pentax DSLR Discussion 3 01-01-2008 12:42 PM
Maximum flash sync speed jshurak Flashes, Lighting, and Studio 19 12-05-2007 12:13 PM
K100D flash sync speed Tyler Pentax DSLR Discussion 2 04-27-2007 12:08 PM
All times are GMT -7. The time now is 01:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
