Originally posted by lurchlarson The two systems are essentially the same in effectiveness.
Lens Based
Pros:
The stabilization is fit exactly to the lens
You can see the stabilization in effect through the viewfinder
Cons
The lens is a lot heavier
The lens is a lot more expensive.
It's not necessarily any better.
Sensor based
Pros
Works with all lenses
Just as effective as lens based stabilization
Cons
Can't see the effect through the viewfinder.
I am a big fan of body-based stabilization.
Shooting both Nikon and Pentax, I'd agree with all of this.
One thing I wonder about is long-term durability. We usually buy lenses thinking they will last 20+ years and bodies maybe 5 years or less. So with the added mechanism and floating element, will these lenses last as long as a lens that has less moving parts (where all the lens elements are fixed in the barrel).
Also don't forget that there are very few if any stabilized lenses under 100mm. With Pentax, you have everything stabalized.
