09-22-2010, 08:10 AM   #1
Battery acid leaked in KX
Hallo!
ich habe seit 2 Monaten eine K-X. Sie macht super Fotos, aber vor 2 Tagen ist mir von einer Batterie nur leicht in den Deckel bei einem Kontakt Batteriesaeure ausgelaufen.
Ich habe den Kontakt sofort mit einem Wattestaebchen gesaeubert, aber seit dem kann man die Kamera nicht mehr einschalten.
Gibt es einen Trick, sie wieder ans Laufen zu bekommen, oder muss; ich zu meinem Haendler gehen, der die Kamera dann wohl einschicken wird?
Lupus
09-22-2010, 09:31 AM   #2
Use the tip of the parer knife scrap off the damaged metal at the contacts until you see the metal is shiny . Also check the connections between contacts .
09-22-2010, 12:26 PM   #3
TAP
TAP's Avatar
As i understand it, you've had the camera for 2 months, correct?
If all else fails, visit the Pentax website or refer to the info that came with your camera and call customer service for warranty information. If you've had your camera for less than a year, Pentax will repair it for free [you just pay for shipping]
09-22-2010, 09:32 PM   #4
TAP
TAP's Avatar
I have not yet made use of my warranty [although i should before it expires], but do beware as there can apparently be problems in doing so.
This is a quote from [a reliable poster] Hinman in another thread:
In warranty period, you are VERY much on your own! In my case, my parts were back-ordered from Japan which carry NO ETA. A typical repair in warranty takes 6 to 8 weeks. And if parts are back-ordered, God helps you for that 1-2 months of waiting with NO ETA given.
Read more at: https://www.pentaxforums.com/forums/pentax-news-rumors/115144-very-disappoint...#ixzz10K75c9YF
09-26-2010, 03:33 AM   #5
Ex Finn.'s Avatar
Try cleaning the contacts with pencil eraser.
09-26-2010, 09:11 AM   #6
macTak's Avatar
I'd try using alcohol--I've used alcohol swabs in the past with great effect on contacts. The best are the little square pads that are generally used for prep before an injection (can get them at any drug store).
09-26-2010, 11:07 AM   #7
Pablom's Avatar
QuoteOriginally posted by TAP Quote
the OP is from Germany, this has nothing to do with him
09-26-2010, 12:40 PM   #8
jatrax's Avatar
Lupus,
What type of batteries are you using?
Clean the contacts and any other area that has the leakage on it. Cotton swabs with alcohol are good, I have also had good luck with vinegar depending on the type of battery.
As I understand you the camera will no longer turn on after the battery leaked. I assume you have tried new batteries?
If the contacts are clean and you are using new batteries then it should go back to the dealer for service.
Just to be sure, this is a digital k-x not the older film KX, correct?
09-27-2010, 10:58 AM   #9
That's pretty much the plan of action I would follow.
09-27-2010, 07:40 PM   #10
If the batteries are made by a reputable manufacturer, it might be worth an attempt to contact them and see if they might offer a form of compensation for their defective product.
camera, den, kamera, pentax help, photography
K-5 Prices leaked - German emergo Pentax News and Rumors 63 09-16-2010 01:11 PM
Nikon D5000 Leaked. PNTXFTW12 Non-Pentax: Canon, Nikon, Sony, etc. 16 04-15-2009 10:17 AM
Acid Trip Workingdog Post Your Photos! 5 05-02-2008 04:02 AM
K20 Prototype photograph leaked !!!! Confused Pentax News and Rumors 21 01-13-2008 01:25 AM
K10D Firmware V1.10 is Leaked! RiceHigh Pentax DSLR Discussion 2 01-19-2007 08:10 AM
All times are GMT -7. The time now is 08:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
