09-23-2010, 09:14 PM   #1
DA 40mm manual focus ?
Hi All
I am new to digital dslr . I have just bought a DA40 but how do you manual focus it?
Thank you in advance for replies
Dave
09-23-2010, 09:26 PM   #2
The thin ring that rotates is the focus ring. Switch your camera to manual focus mode (switch on the left front side of the camera body near the lens mount). Should be manual focusing before you know it. The lens also has quickshift focus which uses the focusing ring, but thats for manually adjusting focus when in an auto focus mode.
09-23-2010, 09:55 PM   #3
dbs
Hi lowspark86
Thankyou for quick reply. I ment f/stop eg 2.8,4,etc
Dave
09-23-2010, 10:15 PM   #4
It must be controlled through the camera. There isn't an aperture ring on DA lenses, but with a digital body you don't need it. Try Av mode on the mode dial. Depending on what camera you have/how it is set up you use either the front or back "e-dials" to scroll through the aperture settings. It is all in the manual if you take a look.
09-23-2010, 10:18 PM   #5
QuoteOriginally posted by dbs Quote
Hi lowspark86
Dave
That's the aperture, not the focus, just to clarify.
Your answer is above.
09-23-2010, 10:28 PM   #6
dbs
Hi lowspark86 and Adam.
Thankyou for all the answers
I will in future be more clear with questions
Dave
09-24-2010, 10:23 AM   #7
Marc Sabatella's Avatar
Furthermore, even with lens that *have* aperture rings, you are better off not using them on modern cameras. Most reasonably modern lenses (say, last 25 years or so) that have aperture rings have an "A" position on them. Leave the aperture locked there and control aperture via the camera dials in Av mode, M mode, TAv mode in cameras that support it (or let the camera choose the aperture in one fo the other auto modes). The advantage of doing this rather than using the aperture ring is that using the aperture forces you to use M mode, disables the built in meter, and forces the flash to always fire full power as well. It's basically a "crippled" camera when using the aperture ring. For older lenses that lack the "A" position, you have no choice but accept this, but it's something you're better off not having to deal with.
09-24-2010, 03:55 PM   #8
dbs
Hi Marc,Adam and lowspark86
Thankyou all for the answers and will take onboard. I need to slow down when shooting so not to get frazzled, auto is the easy way out in a rush.
camera, da 40mm, focus, pentax help, photography
10 Reasons why manual focus primes are better than those new auto focus zoom lenses JoepLX3 Pentax SLR Lens Discussion 188 07-25-2012 03:28 PM
K100D Super - Focus point locked to center in Manual Focus ? JGabr Pentax DSLR Discussion 2 01-25-2010 09:41 PM
Front focus/ back focus on Manual lens. Possible? WangJianWei Troubleshooting and Beginner Help 6 04-20-2009 07:50 PM
For Sale - Sold: SMC Pentax 40mm F2.8 Manual Focus Lens - Minty davealta Sold Items 2 07-10-2008 12:57 PM
Macro: Handheld, Manual Focus, Manual Stop-Down Mike Cash Post Your Photos! 2 06-19-2008 07:14 AM
All times are GMT -7. The time now is 10:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
