09-24-2010, 08:51 PM   #1
Bracketing: other than EV
I was reading an article on photographing sunsets and was surprised to find a suggestion to use the Shutter Priority mode and set up bracketing for the aperture. I don't think the K-x has that feature - is this on Pro Level Cameras only?
I could not find this listed on the K-5 specs either.
09-24-2010, 09:09 PM   #2
Wouldn't you just have to set the camera into Tv mode and enable exposure bracketing? That'll force the camera to have to change the aperture to change exposure.
09-24-2010, 11:02 PM   #3
QuoteOriginally posted by Bill L Quote
Tv (Time Value) is another name for "shutter priority."
Does the article say why it recommends shutter priority mode? If you want to keep DoF consistent (e.g. for HDR), you may want to use aperture priority (or Av - Aperture Value) mode.
09-24-2010, 11:59 PM   #4
akanarya's Avatar
+ take iso to manuel, in order to let the camera to change only Av. otherwise
iso would be taken into account too.
09-25-2010, 01:22 AM   #5
Nass's Avatar
I don't know about the K-x, but this is a K-7 feature, yes. Bracketing works differently on Tv and Av modes. On Tv, the bracketing is done using different apertures (the time value (Tv) is kept constant). On Av, the bracketing is done using different shutter speeds (the aperture value (Av) is kept constant). On Sv, ISO is kept constant.
09-25-2010, 01:33 AM   #6
QuoteOriginally posted by Nass Quote
It's the same with the K-x
09-25-2010, 02:11 PM   #7
If I understand this correctly, the camera will vary the aperture in Tv mode to obtain the EV bracket that is "dialed" in.
09-25-2010, 02:14 PM   #8
Yes, it will either vary the aperture value or the ISO level (or both). Shutter speed will remain the same for all bracketed shots.
09-25-2010, 04:45 PM   #9
Marc Sabatella's Avatar
Correct. In case it isn't clear (your original question suggests it isn't), EV can never be controlled in any way *other* than by changing aperture, shutter speed, or ISO. Those are the three basic parameters of exposure. EV compensation is just an indirect way of telling the camera to change one or more of those three parameters. Which parameter the camera will change depends on the mode your are in. In Av mode, the camera must hold aperture constant; in Tv mode, it must hold shutter speed constant. ISO must also be held constant unless you have Auto ISO turned on. When you dial in EV compensation (either directly or by using bracketing), the camera is free to change any parameter not held constant.
09-25-2010, 06:00 PM   #10
Thanks for the explanations; I never considered how the bracketing was produced. Pretty obvious now that everyone has explained it. Thanks,
Exposure Bracketing on the K-x noahpurdy Troubleshooting and Beginner Help 7 12-26-2009 10:28 PM
Kx - MLU w/ bracketing? bnorikane Pentax DSLR Discussion 8 12-24-2009 12:29 PM
K110d and Bracketing warrenstilwell Troubleshooting and Beginner Help 4 11-24-2009 08:31 PM
bracketing with the k10d jamescp Pentax DSLR Discussion 5 02-17-2009 08:07 PM
Bracketing Ed in GA Photographic Technique 14 06-26-2007 09:04 PM
All times are GMT -7. The time now is 09:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
