10-01-2010, 08:52 PM   #1
hagiri_11's Avatar
Bringing the K-x along for a jog.. good idea?
Just a weird question..
Is it okay if I decide to bring my k-x along for a jog? Thinking of stuffing it in my backpack..
Would the parts inside be damaged by the continuous vibrations and stuff?
10-01-2010, 09:20 PM   #2
mysticcowboy's Avatar
You're probably okay, especially if you pad it enough. I've certainly hiked many miles with my camera in a pack. The bouncing is less but over time adds up. I've never had a problem. I'd certainly recommend strapping the pack to you securely, otherwise you'll get bruised. Backs are a lost softer than cameras. A fanny pack or belt holster will minimize the bouncing compared to a backpack.
10-01-2010, 09:23 PM   #3
SpecialK's Avatar
It's really no different than driving around with your camera in the trunk or on the floor.
10-01-2010, 10:28 PM   #4
hcarvalhoalves's Avatar
It's a good idea if you have a padded bag.
10-02-2010, 02:18 AM   #5
hcc
hcc's Avatar
I have done it with a prime lens, jogging with my K-7 around the neck when I was chasing some tidal bores. The camera was on and a lens mounted (MF). I was typically jogging 1-2 km, each time, with a few stops every so often to shoot the bore. Although the K-7 was on, I set the sleep mode to 1 min and the camera was often asleep during the jog. (I was holding the camera with onehand to damp any vibration and nasty shock.)
If you use a zoom lens, do lock the zoom when jogging. With my DA18-250mm, I consider essential to lock the zoom when not in use.
Otherwise you already received some good advice: a padded bag is a good idea for a long jog. And do not forget the lens cap.
10-02-2010, 04:04 AM   #6
I have jogged with my camera and I would say that the best situation is to have it in a pack where it is easily accessible. If the camera starts swinging a lot, it won't hurt the camera, but it can be hard on you. If I have it out, I usually have to hold it in my hand as I run, which limits the pendulum effect considerably.
10-07-2010, 06:10 PM   #7
Despite the relative compactness and light weight of the K-x, I think you'll quickly wish for a P&S that shoots RAW if you want a carry-along camera for jogging.
10-07-2010, 06:42 PM   #8
It should be fine but it will probably be a little uncomfortable. To help this, make sure that it is packed tightly into the bag and that the bag cannot swing freely.
camera, k-x, pentax help, photography
Landscape The idea of a good wallpaper Svyatosha Post Your Photos! 1 06-28-2010 07:56 AM
Any good idea about repair? Mojtala Pentax DSLR Discussion 0 12-11-2009 06:46 AM
Does anyone think this is a good idea? ftpaddict Photographic Technique 12 07-17-2008 10:29 AM
Buying a used K10D? Good idea? edumad General Talk 10 05-05-2008 10:10 AM
Photography School -- good idea? hinman General Talk 16 10-07-2007 05:13 AM
All times are GMT -7. The time now is 11:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
