10-06-2010, 06:15 AM   #16
Raylon
Guest
QuoteOriginally posted by violini Quote
Pentax ME, M50mm/1.7, 135mm/3.5, K-x, K-7, DA15mm. DFA 100mm WR Macro.
Holy white balance batman! It's way off!
But yea my K200 was never that good. I simply used the green button to get a starting point and worked from there.
10-07-2010, 02:35 PM   #17
Obs
OK, so here's a photo I took, just outside my apartment. I just ordered a book called "Understanding exposure: how to shoot great photographs with a film or digital camera", by Bryan Peterson, to better my understanding of SLR photography. Thanks again for the help guys.
10-08-2010, 06:00 AM   #18
Nowhere Matt's Avatar
QuoteOriginally posted by boriscleto Quote
You need to stop down or lower the ISO. The K-x defaults to 0.3 when there is too much light.
That is good to know but most times when I point my lens to the sky and get 0.3 setting it is because I have forgotten to remove the lens cap.
10-10-2010, 05:11 PM   #19
"Fogel70:
If using Av-mode a K-mount lens with aperture ring it has to be set on A-position for the camera to stop down the lens.
All pre-A lenses will only be used with widest aperture in Av-mode, so for controlling aperture you need to use manual mode."
On Pentax-M 135mm/3.5, the aperture is controlled by the aperture ring, not the camera body. Use mode M for M50mm/1.7.
10-10-2010, 05:36 PM   #20
pschlute's Avatar
"Fogel70:
Yes we know the aperture is controlled by the lens. The point he was making is that in Av mode any M lens will shoot only at widest aperture irrespective of where you set the aperture ring. You must use Manual mode to allow your aperture selection to work.
10-11-2010, 07:40 AM   #21
OK, it works on mode M. If one does not mind shooting at wide open aperture, Av mode is more convenient to get a correct exposure.
10-11-2010, 08:31 AM   #22
aleonx3's Avatar
On my M135mm, the aperture blades move following the setting on the ring, no DOF preview or stop-down. That's why it works on Av mode.
Both Forgel70 and pschlute were right, any other mode except M mode allows you to change the aperture, otherwise, you are shooting with wide-open aperture. One simple test is to turn the aperture ring to any value and press the green button once, does the shutter speed get changed? Nope.... it stays the same.
Also, with M lens, the metering is changed to center-weigh, so you have to adjust accordingly if you are still thinking matrix metering.
10-12-2010, 09:09 AM   #23
One experiment I'm going to do is to cut or remove the aperture control lever at the base of the lens. Then I can use Av mode without worrying about metering. The drawback is the viewfinder may become too dark for small aperture.
I think the camera firm/soft ware should be revised to allow setting of aperture value when M series lenses are used. (instead of blank F--)
10-12-2010, 10:30 AM   #24
I am at least the second owner of a Vivitar 80-200mm f4.5 that has this type of modification. I as well as a few others can tell you that the lens will perform exactly as you imagine in Av and other program modes somewhat satisfyingly. It eliminates using the green button but does of course darken the scene as you look through the viewfinder as you close the aperture manually.
If you would like, (and live in America) send me a message and we could talk about conditions of me giving you this modified Vivitar lens to play with to decide if you want to mod your own lens.
10-13-2010, 03:46 PM   #25
Obs
I think I may just purchase Pentax-A lenses from this point on, and shoot in Av mode. I find Pentax-M lenses just too difficult to work with; stopping down with the green button just doesn't do it for me. I just purchased a Pentax-A 50mm 1.7, so hopefully all I'll have to worry about is manually adjusting focus.
10-13-2010, 05:42 PM   #26
Lowell Goudge's Avatar
QuoteOriginally posted by Obs Quote
Just get a k10 or K20 with an *istD screen and make it an MF body only. It'll meter just fine
10-13-2010, 07:19 PM   #27
Obs
The only gripe I have with the k-x is the fact that when I stop down meter dark objects with my Pentax-M 50mm 1.4 using the +/- button, the recommened shutter speed is usually some ridicoulous shutter speed like 0.8", or 1.6", I'm talking dark objects even in daylight!
I don't know. What could be the issue?
10-13-2010, 07:47 PM   #28
Obs
After a couple of night shots with the k-x, I have come to the conclusion that metering using stop down via the +/- button is useless. I guess I just save my money for a good DA lens. Can anyone recommend a thread
10-13-2010, 08:02 PM   #29
boriscleto's Avatar
The pictures in this flickr set were all taken using stop down metering with the +- button. While the lighting isn't ideal I wouldn't say the exposures are useless.
50mm shootout - a set on Flickr
What metering mode are you using? Do you have the camera set to Center-weighted or Spot?
10-13-2010, 08:26 PM   #30
Canada_Rockies's Avatar
And this flickr set shows my M 400/5.6 that convinced me to install an LL60 (*istD) screen in my K10d.
K10d + Smcp-m 400/5.6 - a set on Flickr
button, camera, exposure, k-x, mode, pentax help, photography, shot, shots, shutter, subjects, sun
Green Button Stop-Down Metering Acting Differently woefulwabbit Pentax DSLR Discussion 22 03-29-2011 09:56 PM
Green Button Metering with Manual Lens zombieCat Pentax DSLR Discussion 4 02-15-2010 06:07 AM
green button to set exposure slow2focus Troubleshooting and Beginner Help 3 12-14-2009 08:25 PM
k10D metering with M lenses in M mode - K200D doing a better job w/ Green button mrpackerguy Pentax DSLR Discussion 8 10-03-2008 11:53 AM
K10D Exposure w/Green Button in M mode carpents Pentax DSLR Discussion 28 04-28-2007 05:46 PM
All times are GMT -7. The time now is 07:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
