10-03-2010, 10:21 AM   #1
K-7 Big Problem?
Just noticed while importing photos taken with my K-7 that some of them where overly blue in tint. These included both JPG & DNG formats, which makes me worry since it probably means its not some after effect / tweaks gone awry. I just reset the camera to defaults. Any ideas? I hope I'm not shipping this thing off for repair...
10-03-2010, 10:31 AM   #2
Ivan Glisin's Avatar
QuoteOriginally posted by robr7 Quote
Under what lighting conditions? Shooting indoors under artificial light can produce described result in AWB mode, as well as shooting with wrong white balance set. Could you provide more details or attach/post a picture?
10-03-2010, 12:15 PM   #3
i thought white balance would be the problem too
10-03-2010, 12:15 PM   #4
I agree with Ivan - check the White Balance setting in the first instance.
10-03-2010, 01:04 PM   #5
AWB of K-7 is the best out there, but like any other cameras it only works within a certain range (check manual) and it is not foolproof. Try taking outdoor photos of yellow leaves and you know what I mean. The camera would try to correct the yellow tone of the leaves and you would end up with the blue tint. When you import RAW photo, WB setting is also import and shown on screen. Fortunately, the WB is not locked in as in the case of JPEG so WB can be corrected. My 2 cents.
10-03-2010, 01:06 PM   #6
As others have said, Check your WB. If you had it set for Tungsten for instance and took photos in daylight, you would have blue tinted photos.
10-03-2010, 01:56 PM   #7
Lowell Goudge's Avatar
When I got my K7 I had an issue with the photo editor swapping channels and the photos were really blue. In camera Hao do they look. You can put them back on a card and check
10-03-2010, 02:10 PM   #8
If that were the case, All of the photos would have the bluish cast. Of course, I don't know exactly what is meant by "overly blue in tint".
10-03-2010, 02:51 PM   #9
Thanks everyone.
I didnt realize AWB would also affect RAW files, so far after resetting the defaults I have not reproduced it (at least not what I can see in camera) - what threw me off was that it was done in the "Green" and "P" modes and the good / blue shots were mixed in a way that wouldn't make sense that I changed something for a shot or two and then back.
When I get a chance, I'll also try to copy the actual files to a different editor like the Pentax utility to see if they "clear" up or hopefully it will show me something I'm missing that I may have done. I rather be embarrassed that I screwed up something than have to send this away for a while.
10-03-2010, 04:03 PM   #10
Looks like Tungsten was the problem, its shows on the pics with the Pentax utility (quite useful), funny how some shots came out quite nice with it and not others in the same shoot. Any easy way to "undo" / edit that effect out?
Sorry for the noobie panic, dont remember turning this on but I rather it be that... though I think secretly I wanted a reason to trade up to K5. LOL
10-03-2010, 05:52 PM   #11
davidreilly3207's Avatar
Just set the wb correctly on the dngs using any photo editor. The in camera wb setting of a raw (dng) is only used by software to convert to a viewable format. It does not change the actual photo part of the file. I use Lightroom to set every white balance regardless of the in camera setting.
10-03-2010, 07:21 PM   #12
Yep, I was able to use the Pentax utility to save the pics... a bit of warning though, upgrade to the latest 4.21 as 4.11 will do some funky things to your Tungsten pics.
10-04-2010, 08:13 AM   #13
Is that possible? I wanted to transfer a photo from one card to another and the camera wouldn't read it.
If it can be done, how do you do it?
camera, k-7, pentax help, photography
One big money problem. Bucik Troubleshooting and Beginner Help 22 08-05-2010 08:50 PM
(The Big shock) CANON 7D - NIKON D300S & PENTAX K-x ISO PERFORMANCE (The Big shock) starscream Pentax DSLR Discussion 21 01-14-2010 05:17 AM
Big spider, Scary Big Spider (Updated) Damn Brit Post Your Photos! 33 08-28-2009 06:06 AM
i have a big problem with my cp510 printer hll Photographic Technique 6 12-22-2007 06:55 AM
Big Problem with my Video Card..I think...Big Ca Ca benjikan General Talk 19 03-18-2007 11:45 PM
All times are GMT -7. The time now is 11:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
